Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 05-31-2019, 11:53 AM
MarcOFB MarcOFB is offline
Default EuconWS V4.4 not seeing S5
Hi!
So I was running EuconWS V4.0 on Mojave and Pro Tools 2019.5.
No issues besides the appset.
I then updated to euconWS V4.4 and my surface could no longer connect to Pro Tools.
The button on the cm401 just blinks, after a moment the blinking slows down and it carries on like that.
I then tried reinstalling V4.0 and the problem persists.
IP on my mac (pro tools) 192.168.168.1
IP on SC264 (DAW LAN) 192.168.168.2
Subnet mask is 255.255.255.0
These settings worked before i updated.
All ideas are welcomed!
Thanks!
Old 06-20-2019, 11:59 AM
Ulf Ulf is offline
Default Re: EuconWS V4.4 not seeing S5
I am running EUCON Workstation v4.0.1x12611424 and it is working fine. I think this is the last Eucon WS version for System 5!
And if you have installed another later version a will suggest that you reinstall the Eucon 4.0.1
Good luck
Best regards Ulf
Mac Pro 2x3,46 GHz 6-Core OS 10.13.6
System 5 SC264D, CM408x3, CM402, CM401
AM713, MA703, ML530, MC524, FC726
ProTools Ultimate 2019.5, Avid MTRX
Old 06-20-2019, 12:05 PM
Yeah i got it working i had installed the wrong version, all good now :)
eMix 6.1.0 cannot connect to EuconWS 3.6.1 Rpro System 5 14 07-31-2017 05:24 PM
eMix 6.0.3 Hybrid will not connect to EuconWS 3.3.2 David S5 Fusion System 5 35 06-30-2017 05:56 PM
EuconWS 3.5 -> System 5 Hybrid error Rpro System 5 2 10-22-2016 08:30 AM
