Old 04-23-2015, 10:17 PM
lonestarparis lonestarparis is offline
Default Bounce to .wav / cd goes bad
After many years of smooth operation the .wav I burnt on an audio cd can't be played on any audio device, except on my iMac.
It is a standard audio cd, and bouncing as always .wav.
But now the cd identifies as 'Nameless', while before this problem it identified as 'audio'.
Thanks for your help.
Petrik
iMac late 2013, latest version of PT10.3, Digi002.
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Novation 25 sl mk 2 controller
Focusrite Platinum Voicemaster pro
AKG 451 C matched pair
AKG 414 C XLS matched pair
Sennheiser 406 T matched pair
Mackie HR824 mk2
lots of fine guitars
homestudio, retired guitar teacher, enjoying life and recording
Old 04-23-2015, 10:49 PM
Default Re: Bounce to .wav / cd goes bad
Petrik
Make sure you are not bouncing to a a 24-bit wav file. CD players can only play 16-bit wav files, whereas your computer can.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 04-24-2015, 04:42 AM
Petrik
As well as that make sure you're burning a Redbook CD as most CD players won't play 'naked' .wav files. What program are you using to burn your cd's?
Jack
QAPLA!
Old 04-25-2015, 04:05 AM
Thanks for the help.
I usually burn cd's with iTunes. Which worked fine 'till now.
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
Old 04-25-2015, 04:13 AM
You are letting iTunes finalize the cd right?
Jack
QAPLA!
Old 04-25-2015, 08:15 AM
I guess so. I just burn it and follow the iTunes instructions.
(Sorry for reacting so late: my studio is in another town and I can't use internet there)
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
Old 04-25-2015, 11:01 AM
Did you get a chance to check if you are bouncing to 16 bit wav (interleaved) instead of 24 bit wav?
Obsidian Dragon
Old 04-25-2015, 11:34 AM
Yes, 16 bit and interleaved. And when I bounce to mp3 it is perfect. But the client wants it on an audio cd.
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
Old 04-25-2015, 01:07 PM
You can't guess; you have to verify that it is finalizing the cd; then again I've never used iTunes to burn cd's.
Jack
QAPLA!
Old 04-25-2015, 02:19 PM
The 'finalizing' must be the problem then. Should I look for another burning program? Before iTunes I used Nero. That was less easy to use, I recall, but it did the job.
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 12:41 PM
pT 10.3.7 bug: Bounce to MP3 results in delayed audio compared to bounce to wav Imgoinmad Pro Tools 10 0 10-06-2013 12:15 PM
Elastic Properties Stuck? --pre bounce vs. post bounce alithomas66 Pro Tools 9 2 02-07-2012 05:56 PM
Bounce mix - import into new session, bounce again - does this affect quality? Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-13-2011 05:14 PM
5.1 wont bounce. Says "bounce handler cant keep up try convert after bounce...." Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-21-2001 08:28 PM
