easy drummer,easy short cut!
Hi. After much trial and error dealing with ezdrummer2, I've found a method that suits my needs perfectly. I'm old school rock and roll so for right now I'm not interested in all the stuff that drummers probably would consider essential such as fills, intros etc. You know, simple and commercial. I open ezd, and select the tap tempo screen for kick, snare & hi hat individually, then, tap in the timing for each. I drag one measure of each to the song creator at the song start measure and then to my protools timeline for each track. Then I can copy and paste each to the full length of the song. Each drum part is quantized perfectly. I know this is super simplistic but it works for me. Now I need to find a way to add rolls, fills, etc. where needed. possibly additional tracks. It just occurred to me that I've probably posted this in the wrong category so mister moderators please feel free to move it to it's appropriate section. A simple solution for a simple mind!
Re: easy drummer,easy short cut!
What I used to do(been working with mostly real drums lately) was to find fills in the EZdrummer library and drag/drop several onto the timeline, but well past the end of the song. I would then pick and choose which fills(and often just small pieces of them) and copy/paste into the song where needed.
In case this sounds a bit cryptic, some of the fills from the library are a full measure and 2 measures, but I may only need a half measure fill
I do something similar to Albee's technique, except I will add a midi track directly above my EZDrummer track. It's to this midi track that I drag my potential fills from EZ Midi. I drag them above the part of the EZDrummer track that they may be placed.
EZHorses for EZCourses! Thanks, |
Can't you do that all in EZ and then drag it all into PT?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
Hey SpinningDisk. Yeah you probably can but you must remember that in my case I kinda' have to feel my way along.
GregJ and albee. Thanks for both of your comments and suggestions. They both seem to be the method I need to approach embellishing my drum parts. I also failed to mention that I have successfully solved how to record each drum piece in Midi and then transpose each to Audio tracks via busses. I know this seems remedial to you guys but pardon me if I boast a little! Thanks again.
Every success feels great, no matter how big or small
Easy Drummer crashing 10.3.1 | smpkeys | Pro Tools 10 | 3 | 10-15-2012 12:43 PM |
Maybe Easy Fix | littledoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-07-2010 12:46 PM |
EZ Drummer not so easy | Ode Man | Tips & Tricks | 3 | 02-09-2010 05:33 AM |
Keyboard short cut easy question... | Violet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-27-2009 04:06 PM |
Ok, this should be an easy one. | geg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-02-2001 10:25 AM |
