Old 06-28-2017, 05:49 AM
Moviesound Moviesound is offline
Default 16 Softkeys not active
The 16 software buttons underneath the iPad are never lit & active unless I press the bottom left one to de-select them and then press again to re-select them. Then they become lit and active. Have to do this every single time
Anyone else getting this with Eucon 3.6.1?
Old 06-28-2017, 06:34 PM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: 16 Softkeys not active
Is this with PT and have you customized your Appset ?
Old 06-28-2017, 08:02 PM
dez811 dez811 is offline
I have the same issue seems like it times out or something. also using 3.6.1 and Latest Pro Tools
Old 06-29-2017, 01:27 AM
This is with Pro Tools (11) but with the latest applet and after resetting all Eucon and PT prefs. I also don't get the correct functionality with the left edit bank. Write, touch, latch, touch latch, read all do the same thing. They cycle between the modes instead of choosing their respective mode. Trim does not work at all
Unselecting 'dock automation mode follows attention channel' renders the buttons inactive
Old 06-29-2017, 01:48 AM
Can't get the left bank working as it should but have worked out when/why the soft keys stop working.
Whenever I click outside of PT (finder, safari etc) they stop functioning and stop illuminating. I thought selecting assign/lock to application/entire surface would fix this but it doesn't
Can anyone else replicate this?
Old 06-29-2017, 06:01 AM
I can confirm i have 2 artist mix also and the lights go off if I click on desktop or another program even though I have them locked to pro tools.
Old 06-29-2017, 05:56 PM
EddieJones's Avatar
Can you guys post an image of the locking check boxes...I presume you are on 3.6.1 ?
Old 06-29-2017, 06:21 PM
Here is mine
File Type: jpg Screen Shot 2017-06-29 at 9.18.59 PM.jpg (47.7 KB, 0 views)
Old 06-29-2017, 06:48 PM
EddieJones's Avatar
Thanks, I presume you lose all fader control too? I'm on a PC at home and its working OK. I'll test with Mac tomorrow.
Old 06-29-2017, 07:49 PM
no the faders work
Softkeys are binded to macos tbov Artist Series 0 10-13-2016 08:06 AM
SoftKeys customizing - XML OvD Avid S1, S3, Dock and Control App 2 08-17-2016 02:32 AM
Softkeys dedicated to workstation Gregor B. Avid S4/S6 3 01-18-2016 12:09 PM
C|24 and PTHD softkeys fakir_cz ICON & C|24 4 12-01-2011 06:54 PM
Instrument track in-active, without making it in-active Ylle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2007 01:18 AM
