Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 11-10-2015, 04:40 PM
Prentiss Carr Prentiss Carr is offline
Default El Capitan Drivers?
Any word on Mac drivers for the quartet that will work with El Capitan?
Pro Tools 12, Pro Tools Quartet, iMac i7 2.93 GHz
Old 11-12-2015, 03:54 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: El Capitan Drivers?
the current driver seems to be compatible with 10.11!
http://avid.force.com/pkb/articles/d...uartet-Drivers
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 11-12-2015, 04:27 AM
Thanks. Strange thing is the release date and driver version is the old drivers and they just added in the text that it is qualified for El Capitan. I downloaded them and the file names says they are for Yosemite and Mavericks. No mention of El Capitain so I believe they are the old drivers. Maybe the old drivers were tested and work with El Capitain so they did not update them.
I will be glad if the drivers work with El Capitan because I will be able to upgrade my Mac soon. If anyone tries them please post your results and I will do the same.
Old 12-17-2015, 04:37 PM
The drivers seem to work. Unfortunately like others I am still getting the error message at start up that the drivers need to be updated to the latest. When in fact they are the latest. This has been a "bug" for some time. Hopefully new drivers will be released soon as these work but are the same old ones that generate the bogus message at startup.
Old 12-31-2015, 04:39 AM
xLITOSxWAYx xLITOSxWAYx is offline
Pro tools 10.3 el capitain
pro tools driver works with the mbox 2 version 9 standalone drivers
working with mbox2 pro tools el capitain
pro tools 9 version standalone driver WORKS
Old 01-17-2016, 06:04 AM
New drivers (installer) available. Issue seems fixed. I no longer get the "wrong firmware" message.
I uninstalled then ran the new installer. Fixed it. Took a year for the new driver/installer which is ridiculous but at least its here now and fixed.
New installer works as it should also. No more hanging like it is frozen for 15 minutes then finishing the install. Works great now and as it should.
Old 07-16-2016, 08:44 PM
junking junking is offline
I have a problem with protools 12.4.0 and protools duet
my OS X EL capitan 10.11.5
i can't record right now ...
when they fix this problem?
i have to make a beat as soon as i can..
someone please help me out..
Old 05-13-2018, 07:05 PM
booshganoosh booshganoosh is offline
Is this update finalized? hoping to download some video editing software but dont want to shut down my pro tools like how it has happened in the past.
El Capitan and Mbox 2 Drivers. thegame15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 11-26-2016 04:26 PM
Mbox 3 and El Capitan drivers MarcelMendesFilho FireWire & USB Audio Interfaces (Mac) 34 02-12-2016 06:25 AM
S3 and El Capitan - no go Cliffy_Boy Avid S1, S3, Dock and Control App 9 11-16-2015 06:27 AM
El Capitan mastertstudio Pro Tools HDX & HD Native Systems (Mac) 21 10-25-2015 02:55 PM
El Capitan Allan1 Pro Tools 11 3 10-06-2015 07:33 PM
