Pro Tools 11 on mac not showing waveforms
Hey,
for some reason when i import audio into pro tools 11 on mac the audio waveform is not showing, the audio file is still there and playing you just can't see the waveform, anyone have any idea why? |
Re: Pro Tools 11 on mac not showing waveforms
its ok i think i worked this one out,
i was adding the file to the session rather than copying it. when i copy it the waveform shows up fine. |
Did you try "recalculate waveform" ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Track view is set to "Waveform",
and i tried recalculate "Waveform" & thats not working either. still no luck |
Ok,
so i tried with some different files & everything worked fine, possibly just bad files or a bad hard drive. |
Hi
Actually I'm getting a similar problem. If I look in the task menu PT is constantly trying to calculate the waveform overview but never succeeds. Clicking recalculate doesn't help. PT 11.1.3 on a late 2013 iMac running OSX10.9.2 Any ideas? |
Me too. It's only a problem if I have to edit the file after I import it. Once, I had to edit in Audacity, then re-import.
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
I had this happen with the 11.2 version.
I simply had to recalculate waveform overviews from the region bin and all good.
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
.... by that, do you mean, right click on the clip in the regions bin, then select, "Recalculate Waveform Overview"? Still no improvement here.
Yeah, I now have a project in 11.2 where the waveforms no longer draw. It was working fine yesterday in 11.1.3. This is a show-stopper in post.
UPDATE: Ok, I'm super embarrassed, but I did finally notice that all audio tracks were in "block" mode. I'm positive this wasn't the case under 11.1.3. Is it possible this is a new default behavior, or something? In any event, it's all squared away now, but still a head-scratcher about how it got that way. Chris |
Waveforms not showing when recording | Dizzi45Z | Pro Tools 10 | 3 | 10-29-2015 11:10 PM |
PT 8 not showing waveforms | crypt0r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 11-08-2011 07:31 PM |
Pro Tools 9 Waveforms | firebass305 | Pro Tools 9 | 10 | 11-19-2010 11:09 AM |
Pro Tools not showing waveforms (in centre) | TheBeats | Pro Tools M-Powered (Win) | 1 | 12-12-2009 09:22 PM |
No Waveforms showing when I use Rewire | essplode | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-17-2008 09:35 AM |
