Old 11-28-2011, 06:57 PM
xbuzzlightyearz xbuzzlightyearz is offline
Default Harpertown
Recently made the move from a Woodcrest 2x 2.66GHZ machine (ran flawlessly) to an "8" core Harpertown Mac pro.
I had been nervous about making the move after reading all the horror stories but decided to give it a go.
I Installed the native card, pulled up decent sized session, and immediately the computer began go act up. The CPU meter was flying around and constantly getting 9092 errors. I wasn't too surprised given everything i read on the forums.
I decided to call Avid and see if they had cooked up any solution. They insisted that I move the native card to the 4th PCIe slot, I tried it and I immediately began to see an improvement. I was able to Record 16 tracks simultaneously while playing back another 16 with 5 plugins on every track. Giving me 160 plugins recording for 7+ minutes at a 32 playback buffer.
I haven't pushed it harder yet but it was a completely different experience than how Pro tools acted with the card in Slot 2 and 3.
Don't know if others have tried this but it solved my problems, hopefully it solves someone else's issues.
Old 11-29-2011, 06:44 AM
mixwell mixwell is offline
Default Re: Harpertown
That's good news! Avid should really jump on getting this info into their literature so people know to watch out on this machine. As of now, the HD Native users guide recommends slot 2 inside the Mac Pro (universally) so it might be good to update the printed spec for customers using these machines with HD Native Pcie cards.
Adam Brass
[email protected]
DSPdoctor
________________
"Any opinions above are worth exactly what you paid for them."
Anonymous
"If I find 10,000 ways something won't work, I haven't failed. I am not discouraged, because every wrong attempt discarded is another step forward.
Thomas Edison
RTFM
Old 11-29-2011, 12:47 PM
drumster drumster is offline
Good to see you posting on here Roc! Your posts regarding the HD Native system over on Gearslutz are always very informative.
Lynx Hilo Thunderbolt
2013 Retina Macbook Pro 2.7 16 GB of RAM
PTHD 11.3.1 OSX 10.10.1
Old 11-29-2011, 12:49 PM
This is a good suggestion, and one that others should try. In my case, changing the PCIe installation slot did not make a difference.
Old 12-03-2011, 03:27 PM
SaschaP SaschaP is offline
I'm on an 8*2.8 Harpertown and I moved my HD Native card from slot 2 to slot 4 and have noticed a more stable system since.
I also cut my number of processors in the playback engine to 4, down from 7.
I think that when Pro Tools doesn't need to bounce it's processing between the 2 cores it runs MUCH more stable. 1 core for PT, and 1 core for the OS. You'd be surprised at how little of a hit your total processing power takes.
I think this speaks to the fact that PT was never really coded properly for multi-core machines.
Old 12-04-2011, 11:22 AM
glennaudio glennaudio is offline
I totally agree with this. Pro Tools definitely runs more stable using 1 CPU. Hopefully Pro Tools 11 can use all the cores in a machine more efficiently as I sprung for the 12-core.
Pro Tools Carbon | HD Native 2021.12 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Mercury | Komplete 13 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock | S1 | MacPro 7,1: 16-core 96GB RAM W5700X GPU OS 11 1TB SSD +OWC 1m2 2TB SSD (samples) +Sonnet M.2 4x4 4x2TB Samsung Evo Plus SSDs in RAID 0 (sessions)
Harpertown Works! ladewd macOS 27 12-29-2016 09:42 PM
Harpertown Mac Pro and HDX Rubicon Pro Tools TDM Systems (Mac) 12 10-26-2011 05:08 AM
Which Mac Pro to get...nehalem vs harpertown tdblanchard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 01-29-2010 01:32 PM
Nehalem or Harpertown? Compression Records Pro Tools TDM Systems (Mac) 8 11-20-2009 01:42 AM
Can I update or not? 7.4.1 -> 7.4.2 on Harpertown.... RJW1982 Pro Tools TDM Systems (Mac) 1 07-07-2008 05:11 AM
