Old 06-29-2010, 06:41 PM
Mr. Kelly Mr. Kelly is offline
Default 44.1 kHz vs. 48 kHz - why not use the higher?
Hey all,
I've been noticing on here that there are a bunch of people that say that their "standard" sessions are 24 bit 44.1 kHz. I've always used 24 bit 48 kHz sessions, then truncated down to 16 bit 44.1 kHz for mastering.
Anyone have reasons, other than file sizes, to NOT use a 48 kHz sample rate? Does the truncation yield a point of diminishing return, i.e., not produce enough of an improvement to offset the detriments of the truncation?
What session rates do you use?
Old 06-29-2010, 06:54 PM
Default Re: 44.1 kHz vs. 48 kHz - why not use the higher?
In theory, sample rate conversion may cause errors in the audio files. THis is the same logic that records at 88.2(instead of 96K) for a final product CD. The math to convert form 88.2K to 44.1K is simple, vs the math to convert from 96K to 44.1K. My philosophy is simple. If the end goal is audio(CD or uploads) I go 44.1K. If the end goal will be tied to video, I go 48k. In either case, I always record at 24 bit and dither the final 2mix during mastering (even if its nothing more than dither and Waves L2 for a rough CD. I bounce to disk at the original sample rate and bit depth. Any conversion or bit reduction gets done in a separate step in WaveLab(including mp3). Now, having said all this, if your ears tell you that 48K sounds better, then go with it(I have yet to have a client mention it).
Old 06-29-2010, 08:58 PM
Top Jimmy's Avatar
So you had to go and whip out that chestnut huh albee? While it seems logical, it really doesn't matter.
But you are right. It's the SRC that has always been frowned upon. Avoiding it is looked upon as a step towards quality.
Historically, many SRC algorithms have been quite atrocious. While many have improved over time, you can see a visual of where some are currently here. http://src.infinitewave.ca/
And of course, Audioease's world-famous audio demonstrations. http://www.audioease.com/Pages/Barba...a4SRCTest.html
James Cadwallader
Old 06-29-2010, 09:23 PM
I only stated my opinion No one needs to agree, and other views are always welcome(since I would not claim to be the end-all on this one). Besides......he started it
Old 06-30-2010, 07:47 AM
waltz mastering's Avatar
waltz mastering waltz mastering is offline
Anyone have reasons, other than file sizes, to NOT use a 48 kHz sample rate? Does the truncation yield a point of diminishing return?
Truncating causes distortion.
Tom W
www.waltzmastering.com
Old 06-30-2010, 01:19 PM
jazzdrumr jazzdrumr is offline
Ask your mastering house what they prefer. The folks I use don't care what the file is, they play it out analog to their mastering system. Yes, it's a D/A and A/D conversion but they swear by it. Most of what gets distributed these days is MP3. CD's are so 1987! Why let 25 year old technology decide this? My 2 cents.
Old 06-30-2010, 02:38 PM
daeron80 daeron80 is offline
For the most part, it's pretty hard to hear the difference between 44.1 and 48. They're just really close in frequency - about the same as one musical step.
Where it can show up a little more is when you do something that aliases, even only a tiny bit, and then apply distortion of some kind. E.g., poorly programmed soft synths that use some kind of generative function, like an FM synth built with SynthEdit. Or some guitar amp sims.
As you know, aliasing happens when a digital audio system is asked to represent a frequency greater than half the sample rate. Mostly, that's handled with brickwall filters at I/O. But they can sometimes be generated internally through a digital process. When that happens, it produces a new tone at Nyquist minus the difference. 48 has a Nyquist of 24, so if a frequency of 40 is required, a tone is produced at 8 (24-(40-24)). It's like a mirror reflecting those high frequencies back down. The big problem is, they're practically guaranteed to be inharmonic (read "ugly as heck"). Thankfully, they're usually too quiet to hear - UNLESS you apply harmonic distortion. Then suddenly it's harshness city. That's why it shows up with amp sims. They're all about harmonic distortion.
So, even though 44.1 and 48 aren't that far apart, using the higher rate does make it less likely that aliasing will occur, thus reducing the fizzy buzzies that plague many amp plugins.
Another reason to use 48, as albee said, is if it's sound for video or film. If it's going to be output at 48, it might as well start there.
Other than those considerations, I can't say I've noticed any difference.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 06-30-2010, 03:54 PM
I assume you sample rate convert, but instead of truncating why don't you dither when reducing word length?
Izotope has a very good src algorithm as well as dither program.
Tom W
Old 06-30-2010, 04:07 PM
necjamc necjamc is offline
I am learning something from this thread.
Old 06-30-2010, 04:14 PM
chrisdee's Avatar
chrisdee chrisdee is offline
I'v not been able to hear any difference between 44, 48, 88 or 96 KHz, but I'm only on an mbox 2 pro.
Maby better AD/DA converters would make it more audible ?
going higher than 10.6.3 viaspiaggia Post - Surround - Video 2 06-23-2011 04:41 AM
Can I get mp3.dll from 6.7 or higher? jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-13-2006 01:54 PM
Anyone running higher than OS 10.3.4 with 001? duderonomi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2005 07:59 PM
Anyone use JAM v.2.6 with OS 9.1 or higher?? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 09:38 AM
Higher Gain Tommyboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-22-2000 06:48 AM
