Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 02-12-2018, 11:33 AM
yambike yambike is offline
Default HDX in Harpertown PC?
I’ve read that the Harpertown Mac Pro should be avoided for HDX cards but are Harpertown PCs ok for HDX?
Old 02-12-2018, 11:55 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: HDX in Harpertown PC?
Yes the issue was with the power coming off the PCI-e bus....ie it was underpowered.
The document is somewhere on avid's site....but that was the reason.
It had nothing to do with the actual CPU's themselves.
Daniel
Old 02-12-2018, 03:36 PM
Thanks. Much appreciated!
Old 02-15-2018, 02:23 AM
Pete Gates Pete Gates is offline
HDX cards run fine in Harpertown Macs. The problem is that you can brick the card if you do a firmware update on it, something to do with the low level PCIe BIOS, detailed info was never released.
Pete
Old 02-15-2018, 05:43 AM
YYR123's Avatar
Actually that being said reminded me it didn’t say HDX cards.
It was defined as a no go with TDM cards (from what I remember)
Daniel
Old 02-15-2018, 10:39 AM
YYR123's Avatar
Pete is correct here.
http://avid.force.com/pkb/articles/e...m-Requirements
But there was another issues that I remember b/c I had a 3.1 harpertown and HD (TDM) card at the time.....it had to do with an underpowered bus on the PCIE connections.
Oh well it doesn't matter the OP asked about HDX and harpertown......
Daniel
PT 12.7 on a Mac Pro 3,1 - Harpertown acmost Pro Tools 12 4 03-16-2017 06:45 AM
Harpertown xbuzzlightyearz Pro Tools HDX & HD Native Systems (Mac) 5 12-04-2011 11:22 AM
Harpertown Mac Pro and HDX Rubicon Pro Tools TDM Systems (Mac) 12 10-26-2011 05:08 AM
3 displays for Mac Pro Harpertown Mark Ziebarth Pro Tools TDM Systems (Mac) 14 12-28-2010 08:12 AM
Some Crashing - Harpertown + PT8 KingFish Pro Tools TDM Systems (Mac) 5 02-03-2009 12:49 PM
