Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 11-06-2012, 10:29 AM
stephenDuffy stephenDuffy is offline
Default Mbox pro Headphone jack needs repair-HELP!
Not sure why I find this site impenetrable, maybe old age is catching up with me but I can't find any other place to post so here goes...Anyway the tip of my 1/4 inch headphone plug bizarrely broke off in the headphone jack on my Mbox pro. Looks like I'll need to send it away for repair or attempt to do it myself. The box looks totally sealed so it's likely to be a huge pain.
I'm in the SF Bay Area and need this done quickly as I use it in the songwriting class I teach..
any (constructive) thoughts would be helpful..
thanks
Old 11-09-2012, 06:37 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: Mbox pro Headphone jack needs repair-HELP!
If you can't se any screws on the case I would take it to the shop you bought it.
Old 11-13-2012, 11:58 AM
Shabbysheik Shabbysheik is offline
Hey Stephen. If it is an Mbox 3 Pro (rounded grey slate color), there are 4 screws on the bottom right underneath the rubber feet. The feet are stuck on there pretty good, but can be gently coaxed off with a putty knife. The whole case slides off at that point. Not sure if that will be enough to get to the headphone jack.
Jason Shablik
http://www.jasonsound.com
Mbox 3 Headphone Jack Doesn't Work FairChild Getting Started 4 02-03-2014 01:07 AM
Mbox 3 Pro No Sound from Either Headphone Jack unctuous Windows 1 09-16-2011 07:34 PM
Headphone jack repair - Digi 002 rack -expensive? worth it? captain54 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-03-2011 09:09 PM
Mbox 2 headphone jack question weezerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-07-2008 12:44 PM
Replacing Headphone output jack on Mbox? davidsophia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-19-2007 11:48 AM
