Old 08-24-2012, 08:13 AM
Rockman413 Rockman413 is offline
Default How to let PT output high quality video?
I load a high resolution video into PT, but the video in PT is really not that high resolution. How to set the quality in PT?
Old 08-24-2012, 09:14 AM
Lightbulb Re: How to let PT output high quality video?
There is only one (1) video quality setting in Pro Tools, and it only applies if you are working with DV25 video.
Setup-->Preferences-->Operation, look in the lower left for Video, and enable High Quality QuickTime Image (DV25 Only)
Again, if your video uses a codec other than DV25, this will not change your situation.
Old 08-25-2012, 03:09 AM
Default Re: How to let PT output high quality video?
Thanks! Got it.
If the video uses a codec other than DV25, the video quality will be what it is right? It won't output a compromised low quality right?
Old 08-27-2012, 05:25 AM
Thumbs up Re: How to let PT output high quality video?
Correct.
Correct.
the best quality video output for PT capt kirk Post - Surround - Video 12 04-14-2012 06:11 AM
Done with mix, Bouce with high quality QT mikevarela Post - Surround - Video 5 04-21-2008 03:12 PM
High quality D-SUB connectors. Which one? Impala ICON & C|24 9 02-19-2003 04:01 AM
High Quality VGA Extension? DChung Pro Tools TDM Systems (Mac) 4 04-23-2002 01:04 PM
High quality recordings? del cosmos Tips & Tricks 4 02-16-2000 04:41 AM
