Old 07-29-2004, 04:44 PM
skycraft skycraft is offline
Default Recording Banjo?
Anybody have any tips for recording Banjo? I''ll be doing it in a couple of weeks. I was thinking of approaching in the same I way I do with acoustic i.e SM57 or other dynamic close up and then a large diaphragm condenser back a few feet or further depending on how much room I want to pick up. the main difference with a banjo is of course the resonance of the drum head and how that will play into the equation. It will be important to pick up that "twang" but hmm I could imagine that the resonance when properly applied could get real sweet. I'll spend a few hours experimenting for sure.
Any tips? Mic combos? Thanks in advance.
It all clicks and buzzes from over here!
Old 07-29-2004, 08:01 PM
where02190 where02190 is offline
Default Re: Recording Banjo?
I typically use a single 57, micing either under the bridge area or if the player is too active playing (lots of motion) then under where the neck meets the body, pointing toward the head of the body, similiar to how one would mic a snare drum.
Old 07-29-2004, 08:45 PM
Dan M. Dan M. is offline
a Condenser, with about 10% wet reverb...ohhh I get excited jus' thinkin about it...the sm57 could do the job fine, but I know for sure the condensor will work amazingly.Good luck.I ussed an inexpensive Audio Technica 3035.
-Dan
DUAL G5.PT 7
Any banjo players out there? octoruss Eleven Rack 0 06-19-2011 04:14 PM
Ribbon Mic - Recording Banjo Zetajazz44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-22-2005 04:21 PM
mic'ing a banjo? silence_of_stone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2003 01:33 PM
I have NEVER recorded a banjo...any advice?? Nine Spine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 10-16-2002 05:24 PM
Recording Fiddle and Banjo? TimOz General Discussion 3 09-19-2001 04:36 PM
