Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
  #21
Old 05-20-2019, 08:15 AM
arche3's Avatar
arche3 arche3 is offline
Default Re: 2019.5 Ultimate on a Mac Pro 5,1
Originally Posted by K Roche View Post
I am merely computer functional not super savvy, so I
am considering this graphics card and 2 into 1 power connector (bottom under Frequently bought together)) https://www.amazon.com/Sapphire-11265-05-20G-Backplate-Graphics-Graphic/dp/B06ZZ6FMF8 and since I have an late 2010 Apple Cinema Display I am getting the adaptor connector also in the Frequently bought together....
Couple quick questions
As per my system below I have the original Apple stock Graphics card in the bottom slot (#1) then the Avid HD Native PCIe card in the next slot up #2 then the Samsung SSD PCIe in #3 So will the Sapphire 580 fit in the bottom #1 slot ?
And I have read there will be no Apple logo boot up screen with the 580 is that correct ?
Also I do some occasional video editing in Apple Final Cut Pro X and currently with the stock graphics card and storing the files on the original spinner Hard drive disk the rendering can at times be a bit slow.
Do you know if the 580 will speed things up ? and or would I have to upgrade the HDD with an SSD into the HDD bay to notice any significant improvement in render time ?
It it the right card. 580 pulse. It is a fat 2 slot card. I have 580 pulse in slot 1. Then a pcie ssd card in slot 2. It barely clears. If I put the hdx card in slot 2 I don't think it would clear. Or I need to put a small rubber washer to keep cards straight if the fan cases bump. That's what some people do I read on mac forums. They put a small rubber washer on 580 and the next pcie card if it is tight. Bit of a fudge. But the pulse 580 is on the list of cards apple approves for use for Mojave i believe. I'm pretty sure the power cable is the right one. I'm not positive the power coming off the mac pro off hand.
I do think it helps renders. But don't quote me. I think final.cut uses the GPU for it as well as CPU.
No boot up screen. Sometimes it gets stuck. And I have to power off with button on mac pro and restart. Then it starts. Only thing I don't like about this setup. No boot screen.
Sent from my SM-G975U using Tapatalk
  #22
Old 05-20-2019, 08:32 AM
nedd nedd is offline
It's INSIGHT 2 (5.1) plug-in
I have MP 5.1, 2x3.33 cpu, 64GB RAM, SSD's and recently added RX 580 Pulse, OS 10.13.6.
I have also found out that Izotope Insight is giving me A LOT of -9173. It is version 1.05c. I just reinstalled it today and during installation I got that OS error that this software is not optimised for my system, looks like 32 bit app!
So I can conform that even if you put 580, you might still get those errors. But as I also use old Apple cinema display 20", I read here somewhere that those displays are giving troubles!? I will try tomorrow to swap that monitor with another one and see if that helps. I am using 4 displays and all other three are full HD resolutions.
I would love to hear about some other metering plug in that will work in 7.1 or more without errors.
  #23
Old 05-20-2019, 11:11 AM
SDDP SDDP is offline
I spent a pretty penny on insight 2 and a few others. However most studios, networks use insight and from a lot of blogs here and else where it seems to be the most accurate. Especially to meet various specs for everyone. I was using the waves WLM. But insight is more intuitive. I don't think its 32bit since it came out recently and there are no computers that I know of made for 32 bit, well at least not macs in the last 6 years or so
The RX 580 8GB is arriving tomorrow so will install that and then run insight and see. Since as of now, every time it's on the screen in 5.1 format only showing the levels, I get the -9173
If the GPU card does not address it, then I have no choice to upgrade to a 3.46 and mine as well re-do all of my ram to 6 x 8GB 1333Ghz too.
-Mac Pro 5,1 12core 2.4GHz Westmere 40g
-RX 580 8GB GPU
-OSX 10.12.6 on a 1TB SSD Via PCIE card
-PTHDN 2019.5 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX7 Advanced
-iZotope Post Production Suite 3
-iZotope Music Production Suite 2.1
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
  #24
Old 05-20-2019, 05:49 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
I did a vocal session today running at 64 samples. Never have I been able to do that in the past.
This has been the most stable version I have seen in years.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.6 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Pro Tools HD2 8.1.1 | 2 x PCIe Core Card | 2 x Digi 192 | 2009 Mac Pro Eight Core 2.26ghz
  #25
Old 05-21-2019, 06:21 AM
K Roche's Avatar
K Roche K Roche is offline
What Graphics card are you using, in which slot , thanks ?
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB........PTHDN 2018.12 on OS 10.13.6 High Sierra on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2dn Samsung 970 EVO 1 TB --
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
  #26
Old 05-21-2019, 06:33 AM
innesireinar innesireinar is offline
Originally Posted by Darryl Ramm View Post
Oh come on, please don't upgrade Pro Tools in the middle of a project if there is not a serious problem you are trying to solve. Have you rolled back to what you had before that was working? Hopefully that is a quick reboot away or reinstall of Pro Tools.
If there is a reason you need to stay on 2019.5 you need to troubleshoot...
Trash prefs
If you had hyperthreading disabled to run 2018 on Mojave try turning it back on. (oops I guess you did not move to Mojave from your signature)
If you had dynamic plugin processing disabled, try turning it back on (it does seems to help more now).
Make sure your disk cache is on, set to several GB at least, disk IO happening can help trigger a -9173 (seemingly more so than a -6101).
Presumably you are mixing and already maxed out your IO buffer size and maybe already freezing tracks?
Check the system is fully optimized etc.
Troubleshoot plugins....
Or at least, have two bootable partitions. One for working, the other for testing new releases
Avid HDX - PTHD 11.3.2 on OSX 10.10.5 - PT Ultimate 2019.6 on OSX 10.13.6 (II partition) - Cubase Pro 10 - Avid HD I/O 16x16 analog
Mac Pro 5.1 quadcore 2.8 16GB Ram
  #27
Old 05-21-2019, 11:06 AM
If this helps anyone. My original Insight 5.1 (ver1 before ver2) works with no hiccups. The issue is you can't resize it to be super short and narrow at the bottom of the screen to watch levels like I can on the newer and supposedly more efficient ver2.
The original one is square and much larger and overs a good portion of the edit window. but no -9173 popping up at all with it running for hours on end. Every now and then I will put the new Ver2 and....sure enough 9173
-RX 580 8GB GPU
-HD Omni
-BM Intensity Pro
-HALO UP/DOWN MIX
-ANYMIX
  #28
Old 05-21-2019, 12:11 PM
BScout BScout is offline
Zero issues with Insight 2.
Might be the graphics card.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
  #29
Old 05-21-2019, 12:49 PM
Well, I mentioned Apple Cinema Display 20" I (was) using!
Yesterday I swap it with Samsung 22' TV, 1080p...and amazing thing happend; I was playing sessions on 128 buffer with NO errors. Then I load 5.1 session and cpu went to 100, RED. I change buffer to 512 and cpu was around 20%. Insight 1 was on one screen almost at full size. So it looks like those oldish Apple cinema displays are hogs for cpu. Also I had a older version of BX steromaker and updating to latest version helped as well. I am re-checking all the plug ins now and updating as we speak.
But generally, it is good that we have 2019.5, shame about HDX voices, but I am sure it will come soon.
  #30
Old 05-21-2019, 02:19 PM
bartosz idzi bartosz idzi is offline
HOW can a monitor be a CPU HOG? The only thing that comes to mind, is their firewire/and or/usb hub....
Anyway, good for you that it's working better...
Mac Pro 2 x 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.12.6 - Metric Halo 2882 - Pro Tools 2019.6
2019 ultimate and heat mixer Pro Tools 2019 27 05-23-2019 11:26 PM
2019.5 Ultimate on Mac not seeing iLok license (and other possible problems) Pete Gates Pro Tools 2019 21 05-19-2019 10:40 AM
D-Command & PT Ultimate 2019.5 rmccam ICON & C|24 5 05-09-2019 12:49 PM
Vista Ultimate 64 (the ultimate dissapointment) Filmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2009 04:44 AM
