C24 no output and thumping
My c24 output cut off and started thumping. I am pretty sure something died in the monitoring section.
I am 100 percent certain its the c24. I unhooked protools uplink and it still thumps and when I unplugged the dsub from monitors it stopped thumping. Its isolated to the c24. Sending this thing anywhere probably isn't worth it. How do you get these things fixed? Is it even worth it at this point? My first instinct is to buy another monitoring source like a big knob etc. Ideas anyone? |
Re: C24 no output and thumping
before you spend money on a monitor controller, which is a good idea in the long run anyways, I suggested getting into the UTILITIES of the C/24 and select RESET ANALOG PATHS first. Reset all analog everything you can find in the utilities menu and see if this helps.
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2014 07:33 AM |
Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Output | Epik Productions | Pro Tools TDM Systems (Mac) | 8 | 05-03-2013 12:48 PM |
No headphone jack output - Meters showing output | Hotcrazyfruit | Eleven Rack | 6 | 05-06-2012 12:09 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
No output to 1622 *and* master fader shows output? | nettwerk | Pro Tools TDM Systems (Mac) | 1 | 10-30-2000 05:35 AM |
