Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
  #71
Old 07-01-2019, 02:38 PM
creativecontrol's Avatar
Default Re: Nulling Parameter Values
Looks fine here. You may simply need to refresh your browser.
Jeff
Jeff Komar
Applications Specialist, Pro Audio
  #72
Old 07-01-2019, 03:08 PM
BScout BScout is offline
Jeff
For anyone else having problem seeing the images, you have to allow the dropbox tracker through now. [This used to not be the case but seems dropbox has tied shared images to their tracker now ]
It's amazing that Avid can't store and host images for this thread verses using an outside host.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
  #73
Old 07-10-2019, 07:58 PM
Default Expanded EQ Controls
Let's take a closer look at the expanded EQ controls for a Knob Module on S6. The Avid Channestrip plug-in offers 2 Filters, 4 Bands of EQ in addition to dedicated Input and Output controls.
Filters:
Filters 1 and 2 can be enabled using either the bottom left Encoders or the bottom In switches. The Sel switches just above each In switch enable the Band Solo functions for each filter. The second encoder from the bottom controls the Filter Frequency. To toggle the Filter Type, use any of the In switches adjacent to the encoders for Frequency, Q or Slope. The topmost encoder on the filter column toggles the Filter Slope, between 12 and 24dB/Octave. If the Filter Type is set to Band Pass or Notch, the second encoder from the top can be used to adjust the Filter Q.
Input / Output:
Input and Output controls with nothing switched.
Low Band:
For the Low Band, the bottommost encoder adjusts Gain - boost or cut. The associated switched controls, just like the Filters, include In for Band Enable and Sel for Band Solo. The In switches associated with the Frequency and Q encoders toggle the band between Peak and Shelving.
Lo Mid Band:
For the Low Mid Band, the bottommost encoder adjusts Gain - boost or cut. The associated switched controls, just like the Filters, include In for Band Enable and Sel for Band Solo. The second encoder up from Gain controls Frequency, then Q just above it.
Hi Mid Band:
For the Hi Mid Band, the bottommost encoder adjusts Gain - boost or cut. The associated switched controls, just like the Filters, include In for Band Enable and Sel for Band Solo. The second encoder up from Gain controls Frequency, then Q just above it.
High Band:
For the High Band, the bottommost encoder adjusts Gain - boost or cut. The associated switched controls, just like the Filters, include In for Band Enable and Sel for Band Solo. The In switches associated with the Frequency and Q encoders toggle the band between Peak and Shelving.
A higher resolution version of the above image can be found here:
EQ_Expand_Channelstrip
Jeff
Jeff Komar
  #74
Old 08-04-2019, 07:03 PM
Default Swapping Functions into Zones
Let's take a closer look at leveraging all of the various module real estate on your S6 console. We have a configuration which includes dual Attention Knob Zones, a set of Attention Expand Faders, as well as the 2 sets of encoders which are always docked to the Master Touch Module accessible from the Home page. This can be created on either a 5-knob or 9-knob S6 system. I've chosen to create a small 9-knob configuration and configured two Attention Knobs and an Expand Fader zone in that 3rd bucket. You could just as easily configure your 5-knob console by dragging from the configuration slider a block which is Fader, Attention Knob, Attention Knob. After configuring, simply configure the Fader as an Attention Expand Fader.
We're going to first ensure that the option under the Home > Local Options (gear) for Knob View is set to All Functions and not Selected Functions. When viewing the Home page, which shows an exploded view of all possible parameters for the Attentioned track, touching on a block in the Function Scroller will NOT hide the other parameters, but rather, it will show all of the possible virtual parameters arranged in columns by their color-coded function.
All of the interactions described in the below video are performed from the Home page for the Attentioned track. Simply touch any of the small virtual knobs on the touchscreen, then touch any of the Attention Knobs or Faders to dock that type of parameter (by function) into the chosen zone. For Expand Faders, remember that it is necessary to first create Expand Fader Maps for any of the functions that your would like to populate. This includes individual Insert Parameters for plug-ins, Pan, Sends, EQ, Mic Pre, etc.
Swapping_Functions
Jeff
Jeff Komar
  #75
Old 08-08-2019, 07:03 AM
Default Help Us Help You
Let's take a closer look at some new troubleshooting options that have been added to S6 in the latest version: 19.7.0.101
You now have the ability to let S6 automatically collect all of the relevant logs and configuration files from the Master Module with a single button press.
Navigate to Settings > About and touch Collect Files. The Master Module will ask where you want to save the zipped bundle which defaults to C:\Users\S6User\AppData\Local\Avid\S6\. It is certainly possible to change the path from the default if you so choose.
The files being collected include:
MTM Log Files
Titles
Module Data
User Preferences
System Preferences
Surface Arrangement
Network Setup
Expected WS List
Monitoring Settings
Appsets...and more...
I mentioned in a previous post that it can be beneficial to create simple file shares on the Master Module in order to simplify the process of accessing essential S6 files.
Connect to the s6mastermodule:
Here's the default path location when performing Collect Files:
Lastly, WSControl also now includes the ability to Collect Support Files from the local Workstation:
Jeff
Jeff Komar
