Old 06-19-2012, 01:30 PM
6foot4design 6foot4design is offline
Default Assertion line 123 error when trying to import session data/consolidate tracks
Hi guys. Just finished my dialogue session and am getting ready to deliver it and would like to consolidate tracks with 3 second handles rather than copy everything. One of my PFX tracks will consolidate, but none of the others will. I get that same assertion error when trying to import/consolidate any of the other tracks.
Things I've tried:
-I've gone through the troubleshooting guide and done everything on there.
-Deleted all databases using the helper.
-Exported my IO setup from the one session and imported it into the new one
-Repaired permissions
-Removed all peripherals from my machine, especially on the firewire bus.
My system:
-Mid 2010 Mac Pro with 6GB RAM
-OSX 10.7.4
-PT 10.0.0
-My PT drive is an internal set of two 1TB drives in a RAID mirror (journaled)
Highly annoying and any insights would be very much appreciated.
Thanks guys!
Old 06-19-2012, 01:56 PM
Kasper Kasper is offline
Default Re: Assertion line 123 error when trying to import session data/consolidate tracks
Are you getting the error when trying to consolidate regions within the session? or when trying to import/consolidate VIA session data import?
The helper app has a few caveats, I haven't used it in a while but you might have to manually delete some of your database files.
I have had a session corrupt, and nothing can fix it. Try importing the tracks into a new session as is, then consolidate from there.
Or export tracks as a new session.
kasper
Old 06-19-2012, 02:18 PM
Craig F Craig F is offline
I got something similar when I got an AAF that had CAF (Core Audio File, from FCP) files in it
Thank you,
Craig
Old 06-19-2012, 02:49 PM
I'm only getting the error when trying to consolidate through the import session window. I have no problems using the Option-Shift-3 shortcut for consolidating within the session. I use it all the time in dialogue editing.
Craig, this session isn't from an AAF/OMF. It's from a conform done using Titan. Don't know if that makes a diff for you.
Thanks for the responses.
Old 06-19-2012, 07:05 PM
I was more implying that if you may have mixed file types you may have a problem
Thank you,
Craig
Old 06-20-2012, 06:20 AM
Originally Posted by 6foot4design View Post
I'm only getting the error when trying to consolidate through the import session window..
Did you try exporting tracks as a new session?
"Copy audio files"
"Convert to specified format"
any luck with that??
kasper
Import Session Data + Assertion Error digidub Pro Tools 9 1 10-13-2011 09:29 AM
Import session data (+consolidate) or Compacting not working SD2 Pro Tools TDM Systems (Mac) 7 09-26-2007 11:22 AM
Consolidate option in Import Session Data not working SD2 Pro Tools TDM Systems (Mac) 4 07-09-2007 08:27 AM
Consolidate option in Import Session Data not working SD2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-05-2007 03:32 AM
Import OMF Assertion Error, line 160...but why? Nathan W. Post - Surround - Video 6 05-16-2007 02:08 AM
