Error -6031
hi to everybosy
i put my new hd 1 in my pc sistem, thi sistem: Mb asus p5q pro cpu q6600 4 gb ram kingston v: ati 4550 in playback pt8 shows me the error -6031 end stops performance... i set 2 processor for rtas, but... nothing i started digitest and show mefor all 16 channels: peripheral digital loopback test cannel 1 : failed pattern 1 not started (16777209) (failed 4 times) Can you please help me? sorry for my bad english Francesco |
Re: Error -6031
Try updating your ATI graphic driver to the most recent one. Get it from the ATI website only. If this doesn't work, remove the ATI graphic driver and use the default windows graphic driver to see if there is a change. I would try those two trouble shooting steps first. Also, post as a Sandra report so we can see a detailed spec of your system.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Re: Error -6031
ok, i'm going to post it very soon...
tje problem can be the os? i have an xp home |
Re: Error -6031
this is the sandra's report about hardware:
SiSoftware Sandra Sistema Modello : System manufacturer P5Q-PRO Workgroup : ***** Nome Host : ***** Utente : ***** Processore Modello : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Velocità : 2.4GHz Core per Processore : 4 Unità Thread per Core : 1 Unità Tipo : Quad-Core Cache Dati Interna : 4x 32kB, Sincrono, Write-Thru, 8-way set, 64 byte line size Cache L2 On-board : 2x 4MB, ECC, Sincrono, ATC, 16-way set, 64 byte line size, 2 thread condivisi Sistema Mainboard : Asus P5Q-PRO BIOS Sistema : AMI 1104 07/31/2008 Bus : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Supporto MP : No MP APIC : Sì Memoria Totale : 3.25GB DIMM DDR2 DDR3 Chipset Modello : ASUS P45/P43/G45/G43 DRAM Controller Velocità Front Side Bus (FSB) : 4x 267MHz (1GHz) Memoria Totale : 4GB DIMM DDR2 DDR3 Velocità Bus di Memoria : 2x 401MHz (802MHz) Moduli di Memoria Modulo di Memoria : Kingston 99U5429-007A00LF 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Modulo di Memoria : Kingston 99U5429-007A00LF 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Sistema Video Adattatore Video : ATI Radeon HD 4300/4500 Series (40 SP 600MHz, 512MB DDR3 2x750MHz, PCIe 2.00 x16) Adattatore Video : ATI Radeon HD 4300/4500 Series (40 SP 600MHz, 512MB DDR3 2x750MHz, PCIe 2.00 x16) Processore Grafico (GPU) Adattatore : ATI Radeon HD 4300/4500 Series (40SP 2C 600MHz, 512MB 750MHz) Unità di Memorizzazione Fisiche MAXTOR STM3500320AS 500.1GB (SATA150, 7200rpm, NCQ) : 466GB (C:) MAXTOR STM3500320AS 500.1GB (SATA150, 7200rpm, NCQ) : 466GB (E:) HL-DT-STDVD-RAM GH22NS30 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (D:) Unità di Memorizzazione Logiche Disco Rigido (C:) : 466GB (NTFS) @ MAXTOR STM3500320AS 500.1GB (SATA150, 7200rpm, NCQ) Disco Rigido (E:) : 466GB (NTFS) @ MAXTOR STM3500320AS 500.1GB (SATA150, 7200rpm, NCQ) Pro Tools HD (D:) : 8GB (CDFS) @ HL-DT-STDVD-RAM GH22NS30 (SATA150, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Periferiche Controller LPC Hub 1 : ASUS LPC Interface Controller Controller Legacy LPC 1 : T0 A5-13h Periferica Audio : PC Partner R700 Audio Device [Radeon HD 4000 Series] Codec Audio : ATI (AMD) AA01h Porte Seriali : 1 Controller Disco : ASUS 4 port SATA IDE Controller Controller Disco : ASUS 2 port SATA IDE Controller Controller Disco : ASUS 6121 SATA2 Controller Controller USB 1 : ASUS USB UHCI Controller #4 Controller USB 2 : ASUS USB UHCI Controller #5 Controller USB 3 : ASUS USB UHCI Controller #6 Controller USB 4 : ASUS USB EHCI Controller #2 Controller USB 5 : ASUS USB UHCI Controller #1 Controller USB 6 : ASUS USB UHCI Controller #2 Controller USB 7 : ASUS USB UHCI Controller #3 Controller USB 8 : ASUS USB EHCI Controller #1 Controller FireWire/1394 1 : TI TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller Controller FireWire/1394 2 : ASUS IEEE 1394a Firewire Controller Controller di Sistema SMBus 1 : Intel 801xx/63xx SMBus Servizi di Networking Adattatori di Rete : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller - Miniport dell'Utilità di pianificazione pacchetti (Ethernet, 100Mbps) Risparmio Energetico Stato Alimentazione Esterna : In linea Sistema Operativo Sistema Windows : Microsoft Windows XP Home 5.01.2600 (Service Pack 3) Conformità della piattaforma : x86 |
Re: Error -6031
Make sure to have the lan ports disabled that are not in use. No internet connection. Diable onboard audio. Swap the order of the hd cards.
Re: Error -6031
ok, i'm going to try it!
Re: Error -6031
nothing to do...
it doesn't works the same error in playback without effects |
Re: Error -6031
I'm very tired... I don't know what i should do...
Re: Error -6031
Re: Error -6031
have you tried pulling out your cards and reseating them?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
Run out of CPU error 6031 | Roland Clarke | Pro Tools TDM Systems (Win) | 0 | 01-22-2013 08:41 AM |
error -6031 | cwarrenk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-09-2009 10:39 AM |
Possible fix for DAE error -6031 | dvine | Pro Tools TDM Systems (Mac) | 0 | 06-09-2003 07:50 PM |
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O | booyaaslam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2002 01:55 AM |
DAE error -6031 | binet | Pro Tools TDM Systems (Mac) | 1 | 07-09-2000 06:59 PM |
