Old 11-19-2009, 02:14 AM
D'Animation D'Animation is offline
Default GRM tools automation bug?
Hi all,
Anyone having problems automating parameters in GRM tools Shuffler? Wanted to automate the fragment and delay parameters at once whilst using the 2-D potentiometer (i know this can't be directly automated though). So went to ctrl+option+cmd click the fragment parameter and i get a main thread error - Protools crashes and have to restart, trash prefs etc. Its repeatable for delay too BUT I can go into the 'auto' menu and manually select these parameters for automation - record a pass and its fine
Anyone else finding this? Have sent same info to GRM tools support too. Running a Harpertown 8 core Mac Pro, 8GB RAM, PT's HD 8.01, HD2, Mac OS 10.5.8, GRM tools Classic RTAS bundle v.2.0
Thanks
D
Old 11-19-2009, 05:23 AM
JamesH JamesH is offline
Default Re: GRM tools automation bug?
I've had a few weird automation issues, mainly with GRM Doppler and FreqShift. Neither crashes ProTools though- I just get that the plug-in won't be changeable at all until I reboot. Will let you know if I have a similar problem to you
James
Old 11-19-2009, 06:41 AM
Thanks James - about to do a whole lot of vehicle scenes with lots of Doppler so i hope its in the mood to behave!
D
Old 11-19-2009, 06:49 AM
reichman's Avatar
reichman reichman is offline
Create snapshots, then automate only the superslider, and things should go more smoothly.
Old 11-19-2009, 08:46 AM
Cheers for the tip Reichman - so that is where the superslider shines! Only had the plugins awhile so haven't had huge use for it so far
D
Old 11-19-2009, 01:01 PM
Grmtools Grmtools is offline
Hi everyone,
Here's a tip about automating the 2 D Controller in GRM Tools. The 2 D Controller in GRM Tools plug-ins, controls different parameters in each of the plug-ins. You can tell which ones are being controlled by looking at the sliders and numerical values that are being changed by the 2 D Controller. In the Doppler plug-in for example, it's the X and Y positions. If you select those parameters for recording automation, you'll see the 2 D Controller become activated to record the automation you perform.
We're also about to post a video on automating GRM Tools using the Band Pass plug-in as an example and it addresses automation of the 2 D Controller.
You can check for that at http://www.grmtools.org
Please be sure to report any bugs or support quesions here: http://www.grmtools.org/supportregma...ilsupport.html
We'll do whatever we can to help.
Thanks,
GRM Tools support
Old 10-08-2014, 08:21 AM
joachim's Avatar
joachim joachim is offline
http://duc.avid.com/showthread.php?t=359347
The problems mentioned in the first post still happen 2014 on
Win7 Pro , PT 11.2.1HD , GRM Tools 3.5.2 when the plugin parameters are automation enabled !
Without being enabled : no crash/quit.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Conforming Automation in Pro Tools tanjerinepost2 Pro Tools TDM Systems (Mac) 1 05-30-2011 12:38 AM
What is the deal with Pro Tools automation??? sethbrand Pro Tools M-Powered (Mac) 4 03-26-2008 06:06 PM
Clear ALL Automation in Pro Tools 6? soul Pro Tools TDM Systems (Mac) 2 02-29-2008 12:43 PM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
Pro Tools Automation Cutting Out Measuring Man Pro Tools TDM Systems (Mac) 4 07-25-2002 12:22 AM
