Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 03-11-2012, 06:19 AM
bonzerboy bonzerboy is offline
Default Miroslav Philharmonik problems/PT 10
Not sure what happen but all the sounds are gone? I went to reinstall the sounds but still says it cannot find instruments 2 & 3 anyone else have an issue? also all my other products sample tank etc, looks like all the sounds are gone??
Wow am I groovy or what
Old 03-11-2012, 07:56 AM
spenner spenner is offline
Default Re: Miroslav Philharmonik problems/PT 10
Have you checked the PREFS (on the IK VI) to make sure that ROOT points to the folder containing the sample library?
Old 03-11-2012, 09:42 AM
Yes i did point it to the dir. For some strange reason sample tank and every thing from Ik with sounds, the sounds are gone since loading PT 10. I made a new folder put all sounds for the PHIL H and pointed it in pref. Then when it opens it will load some sounds but anything in the 2 or 3 instruements it says cannot fing??????????? baffliing batman
Old 03-11-2012, 10:21 AM
I reinstalled the sounds, it sees them all. I think something happened and corrupted something but seems to working.. Now if i can figure why the midi randomly stops,,
Old 03-11-2012, 04:17 PM
Benoni's Avatar
Benoni Benoni is offline
I see you are on Windows 7 (from your sig). Make sure you are launching Pro Tools with Run As Admin. IK plugins are notoriously sketchy when they are used in PT that is not launched with Run As Admin.
Just setup PT to default to Run as Admin.
http://www.youtube.com/watch?v=49Zv774gV8s
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 03-12-2012, 06:55 PM
thanks for the tip about run with admin. I never reallyhad any problems before but I will do that on next boot up.
Way to get key switching with Miroslav Philharmonik? gsrokmix Virtual Instruments 4 06-12-2012 02:22 PM
Recommendation: Miroslav Philharmonik from IK Multimedia Jimibrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-04-2011 12:09 PM
What should I do with this Miroslav Philharmonik-problem? stump 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-03-2011 10:52 PM
Miroslav Philharmonik? garnoil Pro Tools TDM Systems (Mac) 22 03-15-2009 08:11 PM
Miroslav Philharmonik wernerbachmüller Virtual Instruments 1 09-18-2006 07:35 PM
