Old 02-09-2010, 03:37 PM
[email protected] Badertime@hotmail.com is offline
Default Oxygen49 MIDI controller powers itself off!!!
I'm running PT8 LE on a mac 10.5.8. reason is slaved. both recognize the maudio controller. I somehow switched to plugin map mode but couldnt figure out how to map to a plugin. and now cant switch back to 'normal' mode. i turned a knob and BAM the oxygen49(blue) turns off (Led goes out) i turn unit off manually and then back on and its ok just to do the same thing again when i turn a knob. HELP!!!
Old 02-10-2010, 07:26 PM
Default Re: Oxygen49 MIDI controller powers itself off!!!
well if anyone reads this and has a similar problem, the fix was you need to be running PT 8.0.1 or higher. i was only running 8.
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
Newbie help required! Hooking up Oxygen49 to Pro-Tools M-Powered Essentials Amarnaman Pro Tools M-Powered (Win) 0 02-28-2012 09:17 AM
Help setting up an Oxygen49 controller Evilmoosehead Virtual Instruments 3 08-31-2011 08:41 AM
Pro tools not recgognizing Oxygen49 play4theworld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-18-2011 02:02 PM
Help trying to control pro tools w/ oxygen49 midi controller aidanm Pro Tools M-Powered (Mac) 1 07-02-2007 07:44 AM
