Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 04-23-2016, 01:44 AM
whsi whsi is offline
Default Duet, 64 buffer missing
First of all, English is not my native language. Please forgive me if I make any mistake.
The minimum buffer of asio is 128 under 44.1k and 96k sample rate in pro tools.
I cannot find 64 buffer no matter what prefered buffer size I set in pt io panel.
Have I done any setting wrong ?
Old 04-25-2016, 11:26 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Duet, 64 buffer missing
No it probably does not provide that low a buffer setting for that interface.
you have done nothing wrong, it is most likely a limitation of the computer and interface and protocol that the interface uses.....
Daniel
Old 04-25-2016, 12:17 PM
mesaone mesaone is offline
According to the user guide, the Duet is capable of a 64-sample buffer with PT 9 and later, and 128-sample buffer in Ableton Live. But maybe this depends on the OS, and using it on Windows means a 128 minimum?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 04-28-2016, 07:46 AM
I found the problem.
System default sound device is set to duet. Change the system sound device to the onboard audio device, then 64 buffer returns.
Old 04-28-2016, 08:42 AM
YYR123's Avatar
Cool thanks for the report
Daniel
Pro duet: could not find a duet connected jotaceworld Pro Tools | Duet & Pro Tools | Quartet 13 03-15-2016 03:33 PM
HELP: ProTools duet firmware updater does not detect Duet mikeserman Pro Tools | Duet & Pro Tools | Quartet 1 10-18-2015 03:12 PM
Duet 2 Melvin90 Buy & Sell 0 01-19-2015 10:23 PM
Missing all the "DAE Playback Buffer Size" settings in Pro Tools 11 & 10? music.mak macOS 1 09-21-2014 10:29 AM
mbox2 mini buffer sizes missing smrpg99 Windows 5 02-13-2011 07:06 PM
