Mbox I/O setup?
I'm fairly new to PT9. I've had my Mbox set up for a while, running computer audio through it works fine, used it with Logic, etc. However when I open up a PT session, the audio plays through my computer speakers (despite the fact that I can't change the volume of my computer while the Mbox is set as my output). How should I set up the I/O? It automatically sets up the Pro Tools Aggregate I/O, and I'm not familiar enough with the I/O menu to figure it out. Any help would be appreciated! |
Re: Mbox I/O setup?
Go to Setup->Playback Engine and at the top of that window next to Current Engine change it from Aggregate I/O to Mbox.
Re: Mbox I/O setup?
Press and hold "n" when Protools is starting (splash page) and it will eventually go to the I/O selection screen where you can select your Interface (Mbox 2 series or Mbox 3 series). This is assuming you loaded the appropriate driver which is a separate download/install.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Re: Mbox I/O setup?
Ah, thank you so much. It was the playback engine. For whatever reason, I was overlooking that because I kept thinking that it must be under the setup->Hardware dialogue.
Thanks! |
I/O Setup for Mbox 2 | Cutlerbri | Pro Tools 11 | 9 | 09-30-2013 08:47 PM |
MIDI SETUP takes long to SETUP and doesnt SETUP | DartagnanSosa87 | MIDI | 3 | 01-28-2013 12:02 PM |
Need I/O Setup Help - MBox 2 | seventhsense | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-19-2008 08:06 AM |
Can Anyone Help Me Setup my MBOX? | dedalus23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-24-2006 06:46 PM |
MBox Setup | Jeff Zacharias | General Discussion | 1 | 01-19-2002 09:28 PM |
