Old 12-23-2010, 08:40 AM
jacknprewitt jacknprewitt is offline
Default Pro Tools 9.0 "Updater" or "Full Installer"?
Hi all!
I was successful in registering my ilok and also registering my LE8-to-PT9 Crossgrade on Avid's website. There are two choices for downloading Pro Tools 9---"Updater" and "Full Installer"?
What's the difference between the two downlad versions and why would I want---or be entitled to---one versus the other?
Jack Prewitt
Rochester, NY
Old 12-23-2010, 08:52 AM
mix109 mix109 is offline
Default Re: Pro Tools 9.0 "Updater" or "Full Installer"?
Hi Jack,
The Full Installer option inlcudes the Digidesign Creative Collection Folder(Xpand2,Mini Grand,Boom,Structure Free which sizes apx 2.8GB)
Therefore the size difference 4210.78(Full) versus 1815.03(Updater)__For MacOSX
Perhaps it is safer to do an uninstall of 8 and do the Full Install.
Old 12-23-2010, 09:25 AM
Elogical4now Elogical4now is offline
I installed the Updater. I already had PT LE 8 installed. The update went smooth as butter and I haven't had any problems.
However, Judging from what I've read lots of people elect to do a complete uninstall, then do the full install of 9.
Old 12-23-2010, 10:33 AM
+1. Same experience here.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 12-23-2010, 10:38 AM
Park Seward's Avatar
Park Seward Park Seward is offline
As a general rule, I'd do an install over an update. Digi does recommend a full install with PT9.
I did an uninstall and then an install and everything work out well.
Digi also recommends installing the hardware drivers first.
And after installation, search and destroy any incompatible plugs.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 12-23-2010, 08:24 PM
formfunction formfunction is offline
Now that is best advice to be had!!! It may take a few minutes, but well worth the time. ff
Old 12-23-2010, 09:39 PM
Eric Lambert's Avatar
One update and one complete install (a new computer) - both work equally well.
Why do we still not have an app, or a function within ProTools, which does this automatically, at least a function informing us when a plugin is out-of-date.
Each plugin manufacturer registers their updates via Avid (using their simple web interface), and ProTools communicates with this database (when asked to) and finds mismatches within your plugin folder. An auto-updater which downloads the appropriate version would be keen (a la Version Tracker), but a simple heads-up would be great.
If the manufacturers couldn't be responsible enough to keep the database up-to-date on their own, it would only entail a couple hours of work each week by a guy sitting at a laptop searching the web. Yeah, that's what assistant engineers are supposed to do, but do they?
This would be pretty simple folks. Let's go!
Old 12-24-2010, 08:47 AM
DetroitT's Avatar
DetroitT DetroitT is offline
As far as Avid plug-ins I did see a not-compatible plugin pop-up for one BF and older dynamic II. They were auto-moved out of the Plug-in folder.
[IMG] code is Off
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
I can´t find the "Pro Tools 9 full installer" in my AVID account anymore Alfa_Heal Windows 0 02-08-2012 02:09 PM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
PT9 LE crossgrade - "Full" or "Updater"? Willie Myers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 04-19-2011 08:28 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
