Old 03-18-2009, 11:43 AM
K2NOMII K2NOMII is offline
Default Default Velocity Settings for MIDI
Hi guys,
Does anyone know how to change the default velocity setting of 96 for MIDI in Pro Tools to 127, I keep changing and saving but as soon as I open again it goes back to 96, Any ideas?
Thanks.
Old 03-18-2009, 08:47 PM
Default Re: Default Velocity Settings for MIDI
Setup>Preferences>midi tab
Old 03-20-2009, 02:20 AM
You said to go "Setup>Preferences>midi tab" but I can not see the part where I can change this setting, btw I'm using Pro Tools 8 LE, maybe this has changed since last update.
Regards,
K
Old 03-20-2009, 02:21 AM
Regards,
K
Old 03-20-2009, 02:56 AM
musicalavtech musicalavtech is offline
Regards,
K
It's no longer in the preferences-midi tab of PT8. It's at the display in the toolbar of the edit window. If all one did was launch PT8, change the default midi note velocity, then PT will not save that change. A work-around is to change the default velocity, then add a midi note, then undo and save. Then the next time you launch PT, it will reflect the change.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 03-20-2009, 06:15 PM
Sorry about the curve ball. I was remembering 7.4 and didn't notice they changed it.
Old 06-25-2017, 12:27 AM
levelaudio levelaudio is offline
Resurrecting an old thread because I can't find one any closer to my issue.
New MIDI tracks in Pro Tools 10 are always created at 96 "volume", which is actually MIDI velocity level. And if I save and close my template with the tracks set to 127, it opens/creates new sessions with them at 96.
Anyone know how to make Pro Tools default "volume" (velocity) for *new* MIDI tracks 127 instead of 96?
Old 06-25-2017, 02:06 AM
Marsdy Marsdy is offline
No. It's a pain in the a** so I never use the MIDI volume fader. (That's not where you set the default MIDI note velocity BTW.)
I've found you need to write a MIDI volume event of 127 at the start of the track to make it stick which is why I never use it. If you don't touch it VIs will play at their default volume which is what I personally prefer.
I find it much neater to adjust overall instrument volume with the Instrument Track fader so you can use break point/node based automation and automate expression (MIDI CC11) for dynamics.
Dave Marsden
UK
Old 06-25-2017, 08:10 AM
Okay. Thank you for the response.
Just FYI, normally this isn't an issue when using instrument tracks. However, when using a MIDI track to control an external synth that doesn't have the most ideal output level, I find myself adjusting the MIDI track volume up to the max 127 fairly often.
Any way to set the default velocity? Mike1983 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-14-2009 06:25 PM
BFD and default velocity levels GregJ Virtual Instruments 1 09-30-2007 08:25 PM
default midi settings in pt7m? catpuke MIDI 2 08-24-2006 08:32 AM
Is the 002, and it's default settings enough? Aze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-25-2003 07:27 AM
MIDI default velocity...Roy? murph16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-04-2002 08:24 PM
