Old 07-31-2007, 04:37 AM
uber noob uber noob is offline
Default Re-wire is non-existent!!
OK, so I'm running Pro Tools LE 7.3 with an Mbox 2. I bought the system as the 'factory bundle' and have had problems accessing re-wire within Pro Tools. At college, I was able to access this by selecting 'instruments' from the inserts menu. With this version it doesn't seem to be the same. Is there another way to access re-wire?? Do I need to install re-wire separately??
Please help, I've been trying to sort this for months now, and feel like I've wasted a lot of money on a system that doesn't even work properly!!
Thank you!!
Old 07-31-2007, 05:08 AM
Ru_C Ru_C is offline
Default Re: Re-wire is non-existent!!
..join the club, & maybe this thread..
http://duc.digidesign.com/showflat.p...part=1#1176150
xx
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 07-31-2007, 07:23 AM
mnoxious mnoxious is offline
This worked for me, I received it after I contacted Tech support at Propellerhead:
"The problem should be solved if you search for and delete the Application
Support/Propellerhead software folder and the Reason files in
username/Library/Preferences folder and reinstall the software.
Do a system wide search for the following files:
Rex Shared Library
ReWire
Reason Engine
Reason Preferences
Delete all instances of found files having the exact names as above.
Delete your Reason folder, ensuring you have moved any personal files which you
might keep in your Reason folder before deleting it.
Reinstall Reason.
Best Regards,
Tony Reese
Line 6 Propellerhead Support"
Old 07-31-2007, 08:36 AM
DigiTechSupt's Avatar
Thank you!!
Which computer model and OS version are you running?
Avid Audio Tech Support
Support FAQ
Old 07-31-2007, 04:01 PM
Default Re: Digi
OS X 10.4, 2.0Ghz, intel based, running Reason 3.0 into Pro Tools 7.3. Will try un-installing Reason files and installing 3.5 update.
Thanks.
Insert key non existent on EuControl (Win7) djmichaelwenz Artist Series 1 10-16-2012 09:36 PM
GML Eq crashing my system, Avid email support non-existent. James Lugo Pro Tools TDM Systems (Mac) 5 03-15-2011 03:45 PM
Older session- non-existent VST plug-in- crashing PT stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-16-2009 08:57 AM
Low Latency Monitoring non-existent in Mpowered??? earhere Pro Tools M-Powered (Mac) 1 02-09-2006 12:40 PM
Wire this... spicyitaliano Pro Tools TDM Systems (Mac) 4 01-27-2003 10:55 AM
