Old 06-28-2017, 05:52 PM
john1192 john1192 is offline
Default Command Modifier not resetting Sends ..
hi, Command Modifier not resetting Sends .. just what it sounds like .. if you open the softkeys window at the bottom and hold the command key and then try and Double Tap a Send to reset it to Unity (0) nothing happens ..
is this suppose to behave this way or is this a bug ??
both EuCon 3.6.1 and Pro |Control are up to date ..
thank you john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-29-2017, 07:03 AM
crustn crustn is offline
Default Re: Command Modifier not resetting Sends ..
I think it's not cmd but the alt key and you only need to single tap in the send.
Artist Mix sends RECORD Command to Logic and Pro Tool Sepphold Artist Series 1 04-11-2016 07:45 AM
Sends default to -inf preference...resetting all sends to 0 Nathan W. Post - Surround - Video 3 07-15-2011 12:10 PM
D-Command Modifier keys not working Touchwood Studios ICON & C|24 3 03-01-2011 09:12 AM
Resetting D-Command factory firmware ARTHANOR Productions ICON & C|24 0 08-08-2007 01:01 AM
Sends resetting soundguydave Post - Surround - Video 1 03-12-2007 05:41 PM
