Issue Recording Vocals PT12/MBox Pro 3 Input 03 (rear panel) - Works with input 01
Hi everyone,
I am quite new with PT. Problem: When I use a mic plugged in input 03 on rear panel of my MBox Pro 3rd gen (Mic/Line 03 toggle buttom out i.e. for Mic to be active and Front/Rear toggle button 01 pushed to activate Rear inputs) I can hear vocals through the speakers (direct signal from Mic to MBox to Speakers) -BUT- when I try to record on a mono audio track in Pro Tools there is strictly no signal recorded (Track recording activated and Record button On). In the mix window I cannot see any input signal for the audio track. There is no signal going from MBox input 03 to PT via my Mac OS. Note: - I can record vocals in PT via a Mic plugged in input 01 on front panel (XLR-Jack cable). No issue. Signal goes from Mic to MBox to PT via Mac OS And, - I tried to record vocals in AUDACITY. Works fine using Mic in input 01 on front panel, but as for PT, does not work at all when Mic plugged in input 03 (rear panel XLR-XLR cable). Analyse of the problem: Looks like there is something wrong with Audio MIDI setup of my system because the issue is the same for Pro Tools and AUDACITY when trying to record via input 03 of the MBox. Question: Does anyone understand what’s happening here? Can anyone help me? Thanks in advance for the time you spend to answer. Hereafter my setups: Pro Tools setup: Hardware setup: Aggregate E/S Pro Tools Playback Engine: Aggregate E/S Pro Tools E/S : Input 1-2 (integrated) / Stéréo / Analog 1L 2R / Input (integrated) 1 Mono M et Input (integrated) 2 Mono M - Output / Stéréo / Analog 1L 2R But there is no other input and output possible. In other words on audio track own PT I can only choose from E/S given above (see attachements. Be aware: Being french I have the french version of PT, Entree = input, Sortie = Output) Computer, OS & Material/Software setup: iMac 24 inc Early 2009, Processor 3,06 GHz Intel Core 2 Duo, RAM 8Go 1067 MHz DDR3, Graphics NVIDIA GeForce GT 130 512 Mo. OS X El Capitan Version 10.11.3 MBox Pro 3rd Gen / Firmware 1.0.4 (latest, but my computer is not certified by Avid. Too old) Pro Tools 12 version 12.4.0 |
Re: Issue Recording Vocals PT12/MBox Pro 3 Input 03 (rear panel) - Works with input 0
could it be that you have things plugged into the front and the back at the same time ?? if so, unplug the front and see if that opens up the back for use ...
There is nothing plugged in in the front panel apart from the Mic. On rear panel there is the multiple (MIDI, etc…) plugged in but on his special place not on input 3 or 4.
have you tried it with Nothing Plugged into the front ??
also: try without the Aggregate ... why not just use the Front input and get back to work ?? sorry, i do not own an MBox3 ... this will at least get you a Bump ..
You need to add more ins and outs in the I/O setup. RTFM
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
I tried to set the engine to MBox directly and not Aggregate (in which MBox is declared as a component). Did not work either. Yes for the time being I just use the front panel and forget about the input 03 and 04 for the mic. I suppose that the MBox driver (latest version) is not adequate for my old machine…. I was just wondering if someone had a similar issue with a newer machine, in which case my guess is wrong. Or, it is something else in my setup either in Audio MIDI setup or in MBox setup directly…. |
Yes I noticed having only Analog 1 and 2 as inputs….
How do I add more ins and outs? Manually? There is a thread dealing with this http://duc.avid.com/showthread.php?t...light=MBox+Pro - Subject: Recording Vocals With Pro Tools - Answer from Weird Audio 11-23-2012, 09:51 AM. >>> I tried it but at some point one must link the new Input to the MBox. Weird Audio step by step process says the following "INPUTS , make 1 NEW PATH mono input . set at INPUT 1 on your MBOX click the first box it should show a little blue box in the first input , (should have a M on it for mono) ". I don't see the way to link my new input to MBox…. Stuck here. In addition, the issue might actually not only come from a wrong PT configuration of E/S. As I do have the same issue when trying to record in AUDACITY it is more of a iMAC AUDIO & MIDI configuration issue, or, the MBox driver is not adequate for an old machine like mine (iMAC early 2009). What I notice is that my MBox E/S options in the iMAC Configuration Audio&Midi are greyed out and the volume levels are all at 0 (see attached file - note it is in french ... ). One can notice that MBox is recognized with 4 inputs and 4 outputs BUT all greyed out and at level 0. Is this normal? I would expect the ins and outs not being greyed out and having the option to modify the volume levels of each in or out channel. If someone has an explanation or knows a way to activate the MBox ins and outs in my MAC AUDIO & MIDI Configuration settings ... Many thanks for help. Last edited by lnc77; 03-31-2016 at 12:09 AM. Reason: update |
MBox Pro, Not able to get any signal input from front panel | dkaudio | FireWire & USB Audio Interfaces (Win) | 3 | 12-31-2014 10:59 AM |
MBox Pro Rear Input Jack Problem - Won't work unless the plug is pulled out a bit | RickT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-13-2012 07:23 PM |
MBox 3 Pro Line Input (rear) Gain | Garry R | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-23-2011 03:28 PM |
Mbox 2, Input works, sound for non-protools works... | rmiller9969 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-13-2011 04:13 PM |
headphones fron + rear panel on Mbox | 92accordlxtuner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-19-2005 09:12 PM |
