Old 01-28-2019, 06:16 AM
jyt jyt is offline
Default Re: FIX!! Protools HD 8.1 and Win 7 64 bit
Since then, I got an 192 interface with 16 analog in and 8 analog out for less then $500 CDN that's what almost 99 cents US, and I'm still using PT 8.1.1 and I don't think I will jump to 9 or 10 soon. Instead now I'm getting into building 500 modules, AML, Capi, Hairball, JLM and Sound Skulptor. I find it a way better way to spend my money then switching to HDX.
Old 02-13-2019, 04:44 PM
Sugarnutz Sugarnutz is offline
The problem with Win 7 was that the later updates weren’t “Digitally Signed” and Win 7 64 bit didn’t like that. Pro Tools 10, the latest version to support HD TDM is still not a 64 bit app. Nothing wrong with 8.1.1, just limited to RTAS or TDM plugins. If you have any Waves plugins you can download Waves 9.3 I believe to install the TDM versions, but don’t use it to apply your licenses. I use the latest 9 or version 10 to put my licenses on a USB stick and then use the TDM installer to install the plugins. Not all Waves plugins are TDM compatible, go to Waves website and search “TDM”. The first link with have the installer and a list of plugins that are TDM compatible.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! G ray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-12-2011 07:09 PM
Sending protools projects to other protools users online kdtufan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2008 07:18 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
