Old 10-30-2005, 03:52 AM
JCWarrior JCWarrior is offline
Default Recording Midi Track - Midi Notes Disappear - Help
I created a stereo audi track, a midi track and put Sampletank on the audio track. I created some midi notes with the pencil tool on the midi track, played, everything is fine. I record enable the midi track and the transport, hit play and the midi notes vanish with no sound being played. I tried record enabling the audio track and zilch.
What am I doing wrong?
My goal is to record one midi track with flute from Sampletank 2 and a second midi track with a different instrument from Sampletank 2. How do I get this to work?
Macbook Pro 2.16Ghz, 4 GB RAM, OS X 10.6.8,
1-Maxtor 200G & 1-OWC 80G External Firewire Drive. - Pro Tools 9.0.3
Old 10-30-2005, 04:44 AM
diskoprivat diskoprivat is offline
Default Re: Recording Midi Track - Midi Notes Disappear - Help
1. recording sample-tank-audio onto the same audio-track that has sample-tank as plug-in won't work because plug-ins are post; they come after the recording path. put sample-tank on an aux-track and route this one onto a stereo-audio-track to record on.
2. to trigger two different instruments within sample-tank you'd have to create two midi-tracks that are channeled to the desired sample-tank-instruments.
3. like audio, if you record your midi-playing over existing midi-data, that midi-data will be overwritten and not played while you record (unless you work in midi-merge-mode; adds newly played data to existing midi-events)
Old 11-03-2005, 09:18 AM
Thank you!
Midi Notes disappear akumraza MIDI 9 11-11-2008 05:48 AM
Midi notes disappear neeel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 83 12-15-2007 01:20 PM
Midi Notes Disappear? RokVox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-13-2007 05:55 AM
Midi Notes Disappear? RokVox MIDI 1 08-11-2007 10:12 AM
MIDI notes in 7.0 disappear... scottedog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-17-2005 09:37 PM
