Old 12-19-2011, 11:42 AM
bradswan1 bradswan1 is offline
Default PT 10 and mutetone
What is the status of using mutetone with PT 10, all's well?
Old 12-20-2011, 09:14 AM
john1192 john1192 is offline
Default Re: PT 10 and mutetone
works here ...
cheers
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-19-2012, 09:08 PM
propower propower is offline
Works fine to start but then I get instant crash when trying to deinstantiate it......
PT10.0.1, Lion 10.7.3, Metric Halo ULN8
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 03-20-2012, 04:43 PM
AlexJMR AlexJMR is offline
Hi there,
check the new version. i was getting the same problem, emailed Salvator from Tritone Digital, and in a weekend (Excellent support!!!), he posted a new version of Mutetone. Or you can try to disable (not bypass) the plug-in before removing it. Sorry for bad english.
Regards
Old 11-05-2012, 03:21 AM
apesong's Avatar
apesong apesong is offline
Anyone still have this problem? I still get the same problem as above when I deinstantiate Mute-Tone. This particular system is running Pro Tools 10.3.2, MuteTone 1.0.2, OS X Lion 10.7.5, UA Apollo. If I keep it running, the plug-in runs fine but if I deinstantiate it as outlined by propower above, instant Pro Tools crash/freeze.
Old 11-05-2012, 11:37 AM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Still happened to me and I as well was in contact with the author and he compiled a new version for me ...
The workaround is to inactivate the plugin before removing it.
Waiting around for input monitoring in the software and a workable plugin, I simply upped my hardware so I don't worry about it anymore. Not a solution for all, I know.
MuteTone author did say he'd hoped the AAX version would solve all problems but I don't know when that would be available/released.
BTW, figured I should test before posting this and it still hangs ProTools when removing the plugin.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 11-06-2012, 03:48 AM
quantise quantise is offline
Another thing you need to know if you use a controller, MT requires to be the only device in the controller setup. So you can't use both.
PT 2021.12 Native 2x Universal Audio Apollo 8p and Apollo 8
Mac Studio. M1 Max. OS Monterey 12.3
Avid S3 and Avid Dock. Dynaudio BM5's.
MuteTone update dr_daw Pro Tools 10 0 02-09-2014 03:12 PM
MuteTone is now 64-bit AAX for Mac mesaone AAX Plug-ins 0 02-04-2014 11:05 AM
Mutetone crashes PT10 john1192 macOS 7 04-02-2013 01:30 PM
MuteTone AAX? jacko AAX Plug-ins 1 01-22-2013 01:45 PM
Mutetone and Command 8 together? Blues Bird ProControl, Control|24, Command|8 0 08-20-2012 02:04 AM
