Old 06-03-2010, 02:36 PM
Stig Eliassen's Avatar
Default Boom and "pattern snippets"
How come Boom always plays a snippet of the next beat even though the note triggering the pattern ends exactly on the grid? In other words:
  • note C3 triggers pattern 1 from 3|1|000 to 7|1|000
  • when PT reaches 7|1|000 there's a little snippet of audio (kick in this case) coming from Boom
  • if I trim the note to 6|4|950 it sounds fine
  • if I trigger a new pattern starting at 7|1|000 it also sounds fine
The original session tempo is 105, but this also happens with a BPM of 120, which is "mathematically correct". Sync Mode is set to Beat.
Old 06-03-2010, 03:09 PM
Default Re: Boom and "pattern snippets"
Hey Stig
Can you send the Boom Plug-In Setting?
Aaron Mulqueen - 001 HD Native
Old 06-03-2010, 03:26 PM
Sure. Where do I send it?
Old 06-03-2010, 03:32 PM
YouSendIt
Old 06-03-2010, 03:45 PM
Is it possible to upload the file to Yousendit with a link here? I can't figure it out.
Old 06-03-2010, 03:49 PM
Yes. Alternatively, attach the file to an email. filodirect[at]gmail[dot]com
Old 06-03-2010, 03:55 PM
Sent you an e-mail.
Old 06-03-2010, 04:12 PM
You have a low level Closed Hat at step sixteen but I can't reproduce on a native system Stig.
Old 06-03-2010, 04:23 PM
Yeah, step sixteen is just how I like it.
Anyway, thanks for checking this for me. I appreciate it.
Old 06-03-2010, 04:46 PM
I liked that effect too.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 04:04 PM
"Boom" kick won't work Codycougar91 macOS 3 03-18-2011 02:28 PM
Virtual Intrument "Boom" Issue firsty33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-25-2010 01:20 PM
MIDI loop editing, "pattern style"? puckprotect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2009 11:50 AM
Loading Drum Samples into "Boom" erockrazor Virtual Instruments 5 02-27-2009 06:02 PM
