Pro tools and Playback engine Help
Hi
I have a G5 Dual Processor w/2Gigs of Memory, I am using Pro Tools Le v8 I was previously using an Mbox2 with Pro Tools, Whenever I went to change the buffer size in the playback engine setup i wouls noticed that the highest nuber in there was 2048, I recently upgraded to an 003 Rack+, now when I go to change the buffer size I noticed that the highest number now is 1024, is this normal with the 003 Rack+ or is something wrong with my setup, and if so is there a way to correct this, your help is greatly appreciated. is this going to affect my usage of pro tools, does anyone how i could remedy this. Thank you in advance Last edited by spidey01; 03-26-2009 at 11:20 AM. Reason: elaborate more |
Re: Pro tools and Playback engine Help
Help Anyone?
I'm not entirely sure on this, but from what I've read I think the Mbox series interfaces go to 2048 and the 002/003 series only go to 1024. Not sure why at all, but I think that's the case.
I have 003 factory and macbook w/2gb ram and in the engine playback it gives me the option of 2048.
I recently did upgrade from 7.4 to PT8 and that option is available for me. I dont know if that helps, but thought I let you know |
Same problem as spidey01...
"H/W Buffer Size" can't go over 1024, for a 48kHz session. 2048 is not suggested in Playback Engine... Yet, I've just read in the pdf "What's New for PT8" : "New H/W Buffer Size Settings : up to 2048 for 003 family @ 48kHz" So, what's wrong with us ??? ----- MBPro 2.2GHz - 2GoRAM - OS10.5.6 - Digi003Rack - PT8 - MusicProdToolkit |
Pro Tools 11 Update Playback Engine Problem | justus1900 | Pro Tools 11 | 4 | 12-23-2013 05:02 PM |
Pro Tools could not initialize the current playback engine | barbara.goddy | macOS | 4 | 03-12-2013 08:10 AM |
Need Help with Pro Tools 9 Playback Engine for MAC | James Trashy | Pro Tools 9 | 2 | 09-30-2011 02:18 PM |
Pro Tools could not initialize current playback engine. | mclilmack | Pro Tools 9 | 1 | 08-28-2011 01:49 PM |
Pro Tools 9 playback engine crash | hedroom | macOS | 1 | 02-11-2011 05:34 AM |
