Re: Artist Mix failing to connect 9/10
Connected through a switch. Not sure how to answer the DHCP question. Nothing has changed network-wise for a year or so, these issues started about 2 months ago I'd say.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
You can set the trigger to be when you login and then you can set any delay time you want. Don't use the Startup folder for this. Task scheduler is the right way. BTW, Task Manager just shows everything that will start. It's an aggregate list and will include anything you add to the startup folder or task scheduler (there are actually four different places you can set startup tasks -- 2 more places in the registry). It isn't the one responsible for the actual startup. It is just telling you what will startup from these four places. Each of these places is triggered at a different time in the boot sequence.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
You should really use the EuControl method to make it auto start as thats what we test with.
I should have thought of all this. For several years the only way I could get EuCon to work reliably was delayed starts to the 3 services, with EuControl last. I thought those days had gone, but it appears not.
I meant for testing, not just deleting the startup file etc.
Whilst I have heard of this before its not the norm, so other than delaying EUCON (or completely rewriting it which isn't off the cards either) theres not much i can suggest. |
#16
OK thanks Eddie (really appreciate how active you are here btw - if only main PT forums had someone from Avid this involved!)
Today it wouldn't reconnect by stopping and re-starting even after several attempts and power cycles. However, additionally closing and resarting MC Client fixed the problem. I think I'm going to try and figure out a way to delay start - with long intervals - the different processes, as I used to do a few years ago. Isn't there a third service I need to involve too, or is that no longer used?
#17
Bonus question to the above - there is also a program called EuConStart. What order do I need to manually start which programs / services to best test this? Here are the contenders I know about:
EuConStart MC Client EuControl
#18
I just want to check again so I'm sure as I'm a Windows guy and don't see these issues. If EuControl isn't set to auto start and you start it after Windows has fully booted is everything OK ?
#19
So far so good. One manual start ok, then using Task Scheduler I tried one delayed for 2 minutes after startup - both times it found the Mix first time. I think it starts MC Client first, right? I didn't set that, but it didn't appear in Task Manager until EuControl started.
#20
Just checking, have you tried a complete uninstall of Eucontrol (using the installer's option to uninstall everything). Do a reboot. And then reinstall. (temporarily disable any delayed tasks in task scheduler)
Seems like you are having to jump through a lot of hoops to do something that works flawlessly on my Windows machine. Also, do you have any other programs on that machine that have startup items? Possibly one of those is delaying things to complete. (or you've delayed a necessary service from its natural state of autostart in services.msc?)
Artist mix freeze..How to re connect >? | robreed2 | Artist Series | 4 | 02-03-2019 12:30 AM |
Artist Mix won't connect | mikeyman | Artist Series | 3 | 08-06-2017 06:59 PM |
How to connect artist mix series to studio one 2 | shamanrock | Artist Series | 18 | 03-18-2015 04:59 PM |
how can I connect Artist Mix with Pro Tools 10 | music.lab | General Discussion | 1 | 04-25-2014 08:59 AM |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
