Old 07-04-2017, 10:00 AM
milescoolin71 milescoolin71 is offline
Default MIDI loses sound on instrument tracks
Does anyone know why my MIDI on instrument tracks loses the sound occasionally? I know MIDI is just instructions. I use Xpand!2 and Addictive drums to create sounds associated with the MIDI instructions. Everything functions as it is supposed to except when I save the file, shut down and restart later. When I reopen the session later the MIDI instructions are still there but the sounds associated with the instrument I assigned are gone and the track clips are see through instead of colored as they are when sounds are assigned.
I used to be able to drag the Plug-In to a different slot on the track and the sounds would magically reappear. Now that doesn't even work.
Ideas?
Old 07-04-2017, 11:54 AM
Default Re: MIDI loses sound on instrument tracks
Under the View menu, select Mix windows Shows>Instruments. This shows a row across the top of the MIX window and there will be nothing EXCEPT on Instrument tracks, where it will show a few things, most importantly, what "instrument(VI plugin) will be triggered by the midi info on that track. Make sure its A-not grey'd out. And B-assigned to the instrument plugin. Yes, its SUPPOSED to retain when you save/close/re-open. If its not saving, maybe its time to try trashing prefs and database files(which is a step for any "odd behavior", which this does sound like)
MIDI loses sound on instrument tracks milescoolin71 Pro Tools 12 3 07-14-2017 06:22 PM
MIDI tracks are recording an unwanted instrument sound Jen H MIDI 1 10-05-2012 06:39 PM
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
Instrument tracks won't sound! [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-22-2009 09:56 PM
No sound from "Aux Input" and "Instrument" tracks slowdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-25-2005 03:46 AM
