#5621
Re: Best Desktops for PTLE
[QUOTE]
I'm currently running a Dual 1.25 G4 w/ 1 Gig of RAM, and a single 7200 RPM drive. This thing will do 32 tracks and 30+ plugins, 3 of them being reverbs. Considering a 4800/2Gig/2SATA HD setup more than twice as powerful, I'm excited to see what it will be capable of. |
#5622
Oh, it's certainly a powerful system. Blows away my old setup with an Athlon 64 2800+. I was amazed at how sluggish my old system felt after I upgraded to the Digi002R with ProTools LE 7.1, and now I'm similarly amazed at how responsive it is with the new setup. I had the guitarist over tonight to lay down some acoustic tracks (using a Rode NT5 I just purchased, and I'm pleased with it, too) and everything ran smooth as silk at 96kHz. I added a quick bit of compression and a TL Space reverb for playback, and it sounded just fantastic.
If you'd told me ten years ago that I'd be able to drop just a few grand on recording equipment like I have now and get the kind of sounds I'm getting recording in my spare bedroom, I would have said you were crazy. It just blows my mind that affordable recording equipment is this good these days. And as long as AMD and Intel are both making quality processors and forcing innovations and low prices from each other, I think that the performance is just going to keep getting better and better. As it is, with the newer systems I don't think there would be any problem recording 32 or 48 tracks at a time if Digi just made an LE interface with that many inputs. Not that I have a need for that many right now, but still. It amazes me.
Joshua L. Decatur, AL |
#5623
Thanks for your thoughts MrJoshua!
Stable and reliable system is my priority number 1 too. -n
002R MacBook Pro 15" Focusrite Rode Shure Waves ToonTrack |
#5624
Re: Best System for PTLE for under $1000.00
Allen,
I am thinking of building a new PC with the athalon dual processor that everyone is raving about. Since there are so many strings to this post I need updated information to build a PC (hopefully under $1500.00). What do you recommend? I am currently using a sweetwater cube turnkey system P4 3.2 800fsb with 1 gig ram. I have 2 internal seagate drives and 2 external GT50 FW drives on my current system. Look at my signature and you can see the rest. I want something with no problems and stuff I can buy locally in Houston, Texas. I also need to know if you guys know how to image my system on one of the GT50 glyph drives with acronis 9 to where I can just plug the image and go (I hope there is not a difference in plugging a pentium image to an athalon). Last question. If I build the PC, Install windows then can I just plug my image and go with waves plugs and all others (authorized already on the Ilock key)? Please respond as soon as possible as I want to begin tomorrow. Thanks and you can private massage me or send email to [email protected]
"It aint about the stuff you got..If it sounds right you're finished..Burn it!" For all complaints click here DAW-Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent |
#5625
3 or 4 video monitors
How do I go about hooking 3 or 4 video lcd monitors to my protools le 002rack computer ?
#5626
Re: 3 or 4 video monitors
To use 3 or 4 monitors, you'll need at least two video cards. On a new SLI-compatible system that's no problem - you just use two PCI-Express video cards of the same kind. On an older AGP-based system or a non-SLI newer PCI-Express system, it means you'd need to use one regular video card and one PCI-based video card, which is slower. On my work computer (not the ProTools machine) I use an AGP-based video card and a PCI-based video card so I can run two LCD screens and one CRT monitor.
#5627
ALLEN: Sweeet GIGA Rig?!
Hey Allen...I followed your advice and built a sweet as GIGA 3 & PT LE 7 rig (Allenstein not Quadzilla). Giga now rewire's into pro tools (which I wasn't aware)... Very cool. Runs like a dream.
One thought....is it possible to put either a MIX core or HD core card into this system? Thanks again for the help! Justin
ProTools 2018 1 x Apollo Quad Firewire 1 x Apogee Duet 2 mac/ios MacBook Pro (15-inch,2018) 2.9 Ghz Intel Core i9 CPU 32 GB 2400 DDR4 RAM 1TB SSD System Drive Mac OS High Sierra 10.13.6 |
#5628
HI Allen: I thought I'd try a Q. directly to you since you've been so helpful in the past...
In 2004, I had a local computer guru build me a computer with the components listed in the DUC. Recently, my computer had problems starting. So I called someone else (the original builder is out with health problems). We concluded a new power supply was what was needed and he installed it. Later that day, I turned the radio/receiver on and the AM reception was very full of static. After much testing, I concluded that the static only was present if my printer was plugged in with the USB cable and also if the 001 was plugged in. I think this new problem resulted from putting in a power supply that was not properly "shielded/insullated"... What do you think of my theory? If I buy one of the power supply's listed in the current "Best Computer" on the DUC, do you think the static will disappear, like before? Thanks.. Tom |
#5629
Will this system be OK?
Hi Allen & everybody else!
I have put together components for a new system to work with PT LE & Mbox2/Digi 002. Now I'd like to be sure this choice will be alright before I finally purchase. OK, I thought of the following setup: CPU AMD X2 4400 (socket 939) @ Scythe Ninja + (included fan) MOBO Asus A8N-SLI or maybe the A8N32-SLI (just because of the better heatpipes) The A8V has fans on it, therefore I'd like to use a stable alternative RAM 2 GB for example MDT DIMM Kit 2048MB PC3200 DDR CL2.5 (PC400) 184pin CASE Lian Li PC7 SE PSU Seasonic S12-430 430W ATX 2.0 GRAPHICS Matrox G550 PCIe, 2X DVI, passive, 32MB DVD BURNER LG GSA-4167B Retail FANS 2x 120mm Aerocool Turbine or 120mm Yate Loon D12SL for case and power supply HARD DRIVES Seagate Barracuda 7200.9 250GB 16MB SATA II OR the corresponding 7200.10 model OR Western Digital Caviar (as stated on the first page of this thread) See, I'm still unsure about the right mainboard regarding its onboard firewire compatibility with the Digi 002 and which hard drive would be the best solution for optimal performance with minimal noise emission. Otherwise I suppose everything else should work fine, will it? Can anybody help me out with this, maybe someone with a similar configuration? I would be pleased to receive some feedback ASAP. Thank you very much in advance for your effort, this is indeed a great forum! Greetz, CB |
#5630
Re: Will this system be OK?
Hi all
Nearly time for the big upgrade, and I'm thinking of: Intel E6700 Core2Duo ASUS P5B Deluxe MoBo (Intel P965 chipset) or P5N32 SLI Deluxe (Nforce 4 SLI chipset) 2GB Corsair 6400C4 Pro RAM Approx AU$1350-$1450 And then there is always the good old AMD fall-back: AMD 64 5000x2 ASUS M32N SLI Deluxe 2GB Corsair 6400C4 Pro RAM Approx $1100 Now - the AMD is tried and trusted - then new Intel is the future (or so it would seem!). It looks like I'd pay about 20% more, but get 30%+ or more performance from a cooler running, quieter, cheaper to run machine. Bigger cache, better for CPU intensive stuff? The big question is- WILL IT WORK? Anyone tried this? Keen to hear your thoughts! Cheers Doogz |
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
