Old 07-01-2019, 02:35 PM
Southsidemusic's Avatar
Default Re: I fell for the Bass Fingers plugin and it doesn’t install ..
Originally Posted by musicman691 View Post
I had them as different plugins. To explain further it happened when I added some new stuff to my Abbey Roads plugins - those were W9 and the new ones were W10. Something screwed up somewheres and I lost the W9 plugins. Oh well. But I lucked into a sale Waves had on upgrades and I wup'd everything really cheap coupled with a personal coupon from them.
Been tempted by this plugin but then again I have a real Jazz bass around here The one vi bass I like is the Rick bass from NI. The gui even has Lemmy's hat sitting on a chair. I bypass the internal amp in the plugin and go into either Bassdude from Plugin Alliance or the Ampeg B15 emulation in Amplitube 4. The Jazz bass get's di'd straight into PT.
Thank You for the great info Jack. I see Rob has the exact same problem as I do with the download stopping at the exact same place and just freezes there until I press stop so something is wrong from Waves side here.
I have tried uninstalling Waves Central and installed the latest 10.0.13.1 but still no bueno!!! I am soo farking tired of Waves and the constant Crap everytime I try to install anything new or update something/ i just refuse to Wup for ss long as I can, not a monetary issue but rather just a pissed off standpoint
I can safely say that the damn plugin is worth the money even though we also have a few very nice basses but for my home setup I needed to get a good sounding easy to use bass VI and 24.50 USD was a given after listening to the demo videos. However if it was $1 and still doesn’t work I would still be as pissed off as I am right now!!
Have been reinstalling since yesterday about 7 times and still looks precisely as Robs picture. Just stop at 75-80% of the install/download on both HD and SD options...
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-01-2019, 02:44 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Bummer.... I was going to try and install the two libraries separately...
Another weird thing is the other plug I had in my Wishlist on Waves say I own it.... but I haven’t brought it..... I’ll have to go back and check.... but I’m sure I haven’t brought it yet
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 07-01-2019, 03:08 PM
xrekcor's Avatar
Can no longer download the manual for Bass Fingers off Waves site either
Rob
Old 07-01-2019, 03:20 PM
xrekcor's Avatar
I have a really really nice 1987 3B BL Charvel Bass.... It has such a nice action, had a noisey volume pot which I changed out and seem to make it sounds even better after I did that.
Rob
Old 07-01-2019, 03:43 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I am a NI Rick bass fan too. I also have the Waves Bass Slapper but it doesn't see as much use a the NI. With three real basses, usually just for quick sketches but still.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
  #16
Old 07-01-2019, 05:11 PM
xrekcor's Avatar
Ok I managed to install Bass Fingers with the sample libraries not selected. So it installed and is working at least as a standalone..... the sample folders are empty but does have some presets... that about it... so must be a corrupt sample library
Rob
  #17
Old 07-01-2019, 05:15 PM
But where do the sound come from as thats what we all paid for?
Thanks again for trying out ways to solve this Rob
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #18
Old 07-01-2019, 05:31 PM
xrekcor's Avatar
can change sounds via the presets list that's it..... you can load sample which takes you to a file dialog where you can see and select the two SD and HD folders and all the listed (by the looks) samples which are greyed out. If you select either of the SD HD folder it does a load thing but I don't see any sample list that you can select from. This only installed by not selecting either of the sample libraries so I think what I'm seeing is an empty file map... the samples aren't installed. But the plug works with the presets sounds and sounds pretty good.
Rob
  #19
Old 07-01-2019, 05:40 PM
xrekcor's Avatar
Here is a couple of screen shots Chris..... I have loaded the plug onto an instrument track and triggering with my ReMOTE 25... you can also load it onto a stereo audio track but not mono, so I assume you can use this as a bass guitar Fx maybe.....
I did submit a ticket to Waves
File Type: jpg 01754F89-C363-49F8-BE2E-88E58C42CC2F.jpg (55.1 KB, 0 views)
File Type: jpg 7F62F892-C957-4E5F-AA3F-1D3AB6E460B5.jpg (92.9 KB, 0 views)
Rob
  #20
Old 07-01-2019, 05:57 PM
xrekcor's Avatar
Ok so now that I have installed the plug the waves install shell doesn’t give me any way to then go back and grab the unselected sample libs.
Have to look at it later got to go to a music gathering.... and do music
Rob
HTML code is On
New Bass Fingers, for all you Bass Slapper fans simon.a.billington Virtual Instruments 0 06-19-2019 05:37 AM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
bass amp plugin- what do you use? remis General Discussion 21 12-05-2010 08:25 PM
Guitar/bass synthesizer Plugin ? Jayoel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-26-2009 09:50 AM
Bass Amp Simulator plugin Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-16-2008 06:13 AM
