  #21
Old 05-29-2019, 04:13 PM
deanrichard deanrichard is offline
Default Re: PT 2019.5 plug-in efficiency
As you mentioned, there should be no difference for a single plugin on a single track, except that CPU shouldn't spike. But if the algorithm for using multiple cores has been optimized there should be differences in performance with multiple plugins on multiple tracks. How big the difference is depends on bad the old algorithm was and how good the new one is.
Originally Posted by JFreak View Post
Uhm.. if a plugin algorithm itself is unchanged, it will use 100% the same resources as before 2019.5 update.
What can change; however, is "spiking" behaviour of some plugins -- and because less spiking means possibly more plugins therefore it seems to be more efficient.
I'd just say PT feels snappier as ever before since DigiDesign PT 8.1.1 HD (in other words best Avid so far)
  #22
Old 05-29-2019, 10:17 PM
mikeyman's Avatar
mikeyman mikeyman is offline
http://www.gearslutz.com/board/avid-...tant-tips.html
found this and maybe it can help .Not sure if it is on topic..
  #23
Old 05-30-2019, 04:08 AM
Let me throw this in the discussion: VEPro 6/7. With the efficiency happening in the new PT would there still be a need for VEPro on a single computer setup? A number of people use VEPro to help spread the load out on the multiple cores in a computer. I know that's not the only use for the program but still......
Jack
QAPLA!
PT 11 efficiency? climber Pro Tools 11 6 09-12-2013 09:16 AM
Osx vs Win7 efficiency? tamasdragon General Discussion 4 05-02-2010 11:45 PM
Best Tip Ever to Run Your System at Top Efficiency deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 08-25-2006 11:31 AM
increasing the CPU efficiency... aziel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-02-2003 05:35 AM
