  #61
Old 05-23-2019, 02:17 PM
justinhill justinhill is offline
Default Re: HDX vs Native
Just curious - when we discuss HDX versus native are we specifically talking about the HD Native card/box, or also about Pro Tools software in general i.e. with a third-party interface?
I have no plans to track using my mix setup, but I wonder - given the Quantum 4848 is a Thunderbolt 2 interface like the Avid HD Native box, how the two compare in terms of latency... I'm not one for statistics but I understand the Quantum's round-trip latency is supposed to be class-leading.
Justin Mark Hill
https://theotheroperation.com
Apple Mac Pro 6,1 late 2013 2.7Ghz 12-Core Xeon E5, 64GB RAM, D500 Graphics, OSX Monterey 12.7.1/Pro Tools Ultimate 2023.12/Presonus Quantum 4848 Thunderbolt 2/Digidesign C|24/Focusrite ISA430 MkII/SPL GoldMike
  #62
Old 05-23-2019, 02:31 PM
JFreak's Avatar
JFreak JFreak is offline
All native systems... only difference between Avid HDN and other native interfaces is that Avid HDN has two digilinks which means 64 i/o
Janne
  #63
Old 05-23-2019, 02:41 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
You can't really compare latency numbers between the two because they don't include the interface.
My personal beef is with fader latency. Every console with moving faders has flunked that test for me because it always requires rehearsing moves. DAWs also have varying fader latency. HDX seems better than native.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #64
Old 05-23-2019, 04:32 PM
glogulus2003 glogulus2003 is offline
Originally Posted by JFreak View Post
How so? Historically HDX is ancient and should be replaced with some kind of "accel" version soon..
Though this supposedly coming voice upgrade is going to be a kind of upgrade but still.. history says anytime soon (though don't hold your breath)
It’s just my opinion. I do hope Avid stays in the hardware business though. For me, There isn’t anything that has the same software and hardware integration like pro tools and hdx.
It would be amazing if they offered a more home budget friendly interface similar to hdx.
  #65
Old 05-24-2019, 06:19 AM
Cheesehead Cheesehead is offline
This is an interesting thread, it clearly shows the strengths of HDX in a recording situation. I totally agree having owned HDX, you can record through the software with no problematic latency at all, drop ins, headphone mixes are super tight etc etc. It just works.
However in in a purely 'post' situation, Native offers massively more bang for the buck on a modern fast computer than HDX, whether its HD Native or just using core audio.
Its not always down to voices either. Sessions can be not necessarily large in voices, but large in processing.
Offloading some processing to a card doesn't seemingly always give you more processing power these days.
The to and fro from the card to the cpu eats up resources.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
  #66
Old 05-24-2019, 06:39 AM
feliponk's Avatar
feliponk feliponk is offline
I use an HD native system with Ravenna, I always use 32 ms and no issues, my sessions are small though.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
  #67
Old 05-24-2019, 07:13 AM
JFreak's Avatar
Likely using 32 buffer not 32ms? Monitoring latency has nothing to do with small/large mixer. Only the hardware you're using and playback buffer you have chosen.
Of course you can mess it up with a plugin that introduces insane amount of delay, but that's another story, cannot use those with any system when you create a can mix.
Janne
  #68
Old 03-06-2020, 04:10 AM
bloodstar57 bloodstar57 is offline
i,ve been running a HDN system for 7 years now and have had the chance to work on a HDX system recently. To ear the HDX is much tighter. I don't the know measured differences but we have to remember to sometimes put the analytics down a listen, However, be sure you have a accurate line stage so you hear whats actually going on.
I will be switching to HDX as soon as i can afford it.
  #69
Old 03-06-2020, 06:31 AM
Make sure you aren't comparing a 192 feeding balanced inputs to one feeding unbalanced inputs. Balanced sounds surprisingly better. I've also noticed that HDX plug-ins often sound better and use fewer resources in HDN than native-only plugs.
Interview
  #70
Old 03-06-2020, 07:22 AM
JFreak's Avatar
True, because the algorithm needs to be tuned to comply with DSP restrictions. However same plugin AAX-DSP and AAX-native should sound the same.
Janne
FS: McDSP Analog Channel Native V5, 6020 Ultimate EQ Native V5 soundroad Buy & Sell 31 03-21-2016 06:03 AM
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
FLUX Elixier V3 AAX Native & DSP + Freeware Bittersweet V3 AAX Native & DSP released psmworld AAX Plug-ins 18 01-31-2013 04:16 PM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
