Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-06-2019, 04:26 AM
2ndgear 2ndgear is offline
Default pro tools set up?
Ive been offered a pro tools set up that consists of using my PT12 mac system with getting 2 x 192 interfaces
Its for my home studio that i have drums, guitars (mic the cab), bass (DI & Mic) set up all the time so full time there is 24 tracks in use.
My question is - do i need a desk or can i use everything in the box?
ie - i plug everything to the 192 and use protools to monitor, set up headphone mix, add plug ins preamps etc etc or would i be best getting a desk???
Old 03-06-2019, 05:41 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: pro tools set up?
IMHO you would be fine without, though mixing can be easier with some sort of control surface,("mousing" can get tiring), and outboard gear is great for adding "flavor"
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 03-06-2019, 06:43 AM
cheers! thanks for your help!!! I could always get a DAW controller to sort the mixing!
Old 03-06-2019, 07:26 PM
Looking at this, I hope you have an HDN or HDX card. The 192 cannot connect directly to the computer without one of these cards. Assuming you do, then you can do most anything in the box. I agree that some kind of control surface will help your workflow and there are lots of options at lots of price levels. Here's a few:
Presonus FaderPort(old style) 1 fader, but under $100 used
FaderPort(new version) closer to $200(1 good fader can do a fine job writing automation)
FaderPort 8 or 16(lots more faders, but priced to match)
Behringer X-Touch(8 faders) for around $500
Artist Mix(used-around $600)
If you can hold off for a while, I think we might see new stuff from Avid in the near future(Artist series are getting old). Personally, I am hoping for something like a smaller(and cheaper) S3
Old 03-06-2019, 08:24 PM
Southsidemusic's Avatar
And to add to what Albee wrote You also need a HD license as regular Pro Tools wont work with the HD cards and those 192 interfaces wont work without a HD card.
And if you plan to use older Accel cards you cant run higher version of PT than PT10HD.
If you want to run HD12 you have to get either a HDN or HDX card to use that setup.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-07-2019, 01:08 AM
yeah i know about the card and the subscription ! id be looking at a native thunderbolt to control the 192
Old 04-26-2019, 02:03 PM
You'll probably need a monitor controller of some sort. The 192's don't have any sort of built in volume control/speaker switching/talkback/cue/etc.
Scott Gatteρo
Old 11-13-2019, 03:20 PM
Sugarnutz Sugarnutz is offline
Not to mention $400 for a Digilink license.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Old 11-25-2019, 04:23 PM
Pretty sure that's $299
FS: Pro Tools HD 8 + Pro Tools HD 9 + Pro Tools 9 Bundle iLOK license Delta Music Belgium Buy & Sell 1 02-27-2019 03:33 PM
