Old 03-05-2019, 11:20 AM
RecRoom RecRoom is offline
Default PT Control intermittent connection
MacBook pro with USB to Ethernet connector set to DHCP connected to a simple ethernet switch. I also have an Apple Airport Express hooked to the same switch also in DHCP mode with the network set to bridge mode. PT Control connects intermittently. Any ideas why? I feel like this should be rock solid.
I've got a wireless router, would that work better than a switch?
Jeff Hinton
Editor/Mixer
http://www.jeffhinton.tv
Old 03-06-2019, 07:31 PM
Default Re: PT Control intermittent connection
I think a wifi router connected directly to the computer will give the best connection performance. Having said that, avoid cheap routers(use a dual-band wifi router). Also, I have been unimpressed with the Airport wifi performance
Old 03-07-2019, 08:06 AM
Just for the hell of it I gave every device a static IP and things seem to work much better. I was under the impression that PT control had to be connected via DHCP but that doesn't seem to be the case.
Jeff Hinton
Editor/Mixer
Pro Control Main Unit is intermittent tekis ProControl, Control|24, Command|8 2 07-31-2014 01:18 AM
MIDI I/O Intermittent connection to Pro Tools KentH macOS 4 04-25-2013 09:00 PM
Control Monitor Section STILL Intermittent! a2zproductions ICON & C|24 3 11-07-2008 09:29 AM
intermittent firewire connection legoat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-07-2003 05:32 PM
192 loss and intermittent connection and then audible clock source WestPhillySoulzition Pro Tools TDM Systems (Mac) 0 04-07-2003 09:46 AM
