Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 12-05-2018, 12:48 PM
skiffle skiffle is offline
Default Midi Controllers will not let me select Projectmix
Hi, I am working with PT MP9, ProjectMix I/O and Macbook Pro 10.6.8
I have lost connection between PM and PT.
According to the PM Manual i must do the following:
With the ProjectMix I/O in Pro Tools mode, launch Pro Tools and select Hardware Setup > Peripherals > MIDI Controllers. Under Type, select HUI. Under Receive From, select ProjectMix I/O Control. Under Send To, select ProjectMix I/O Control.
My problem is that 'Midi Controllers' will Not let me select anything other than 'None' Can anybody please help me with this?
Somebody on here had the same PM PT connection problem i'm struggling with and filling in the Midi Controllers as above fixed the problem!
Thanks again,
skiffle
Old 12-07-2018, 11:09 AM
Default Re: Midi Controllers will not let me select Projectmix
Can anybody out there please help with this??
Not seeing MIDI controller (Akai MPK249) under Peripherals > MIDI Controllers Focuret Pro Tools 12 0 05-18-2017 11:22 AM
Midi Predifined options in Peripherals\Midi Controllers menu RuffinMedia macOS 3 03-04-2015 04:54 PM
MIDI Virtual Ports not showing up in MIDI Controllers (8.0.5) emiliojazz Pro Tools M-Powered (Mac) 0 02-18-2013 12:03 PM
Projectmix/Pro Tools/Select a region. yamahadrums macOS 0 03-02-2012 01:45 PM
ProjectMix - Doesn't appear in "Midi Controllers" milet22 Pro Tools M-Powered (Mac) 1 02-14-2007 03:19 PM
