Old 03-10-2014, 12:53 PM
Roland Shaak Roland Shaak is offline
Default PT11.0.2 full ed. + Focusrite Scarlett 2i4 issue
Well i bought all of this in september and am just getting to it....
My scarlett appears in Windows 7 ultimate sp1 CP>sounds and is selected etc and works fine on I/O via computer no PT11- eleven rack is turned off, scarlett is hot and ready and computer isn't running any ugly programs.
scarlett is not detected as hardware
meaning i get the "no hardware detected" by PT11 during initialization process and then i am stuck and the program needs to restart..only way out.
PT detects eleven rack, but not scarlett
BUT it did at one time off the default template any of the three
Usb is plugged into direct to machine i moved to different hops, usb ports.
I also have a AD192 m-audio board installed - basically then i have 3 i/o devices connected. (ap192 works fine converses with 11r via USB or spdif fine
so i have a feeling i need to bark at Focusrite OR
do i need to start a session with 11rack and see if the defaults are set and invoke scarlett
currently i have ap192 disabled but not removed
i am rendering via scarlett and it's working fine as i said..cds, MP3's etc -fine
windows recognizes it by name and model
i'm freewheeling here - any WAG's?
"Bugs suck" - Roland Shaak Windows 95 group beta XX '94, pre gamer's party at Shark club.
Genius hath electric power which earth can never tame. Bright suns may scorch and dark clouds lower, It's flash is still the same.
-Lydia Maria Child
Old 03-10-2014, 01:51 PM
feliponk's Avatar
feliponk feliponk is offline
Default Re: PT11.0.2 full ed. + Focusrite Scarlett 2i4 issue
Hey Roland: have you installed teh latest drivers from Focusrite, specially the ASIO driver for Windows?, without it, Pro Tools never will find the Scarlett.
After the install, when launching Pro Tools press the letter "N" to choose the playback engine, and the Scarlett should be there available.
Cheers.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 03-13-2014, 02:01 PM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Hi Roland Shaak,
Sounds like there are a number of things that could be going on here.
Please feel welcome to contact us directly on this.
http://us.focusrite.com/answerbase/contact
Also check your Device Manager > Sound Video and Game Controllers > Properties > Driver Version.
If you are using 2.5.1 and having trouble please test out this alternate beta 2.5b4.
Make sure to first uninstall 2.5.1 from Control Panel > Uninstall a Program. If you do not do this the computer will keep using 2.5.1 as it is technically the newer driver.
http://beta.focusrite.com/releases/f..._usb2_drivers/
Please contact us directly if this persists.
Best regards.
Kat
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Old 08-20-2014, 10:57 AM
SimpleManiac SimpleManiac is offline
FIXED!
My 2i4 worked fine with Windows audio but PT11 = nothing in or out. After trying a dozen other things I found this post and performed the following steps:
- delete driver rev 2.5.128.1
- DL and install 3.1.4.201 'beta' driver from the site.
- reboot.
BOOOOM . . . done.
Thank you for taking the time to disseminate this information, you saved me precious time. Wrote a thank you note to Focusrite support page hoping you get credit for your thoughtful work. Can't tell you how much I appreciate it.
Thanks Katherine, you rock.
PT11, MacBook Pro and Focusrite Forte latency issue jobey Third Party Interfaces 3 01-14-2014 01:42 PM
Focusrite Scarlett 18i8 kyluigi Third Party Interfaces 6 10-17-2013 08:14 AM
Recording DI guitar with Focusrite Scarlett 2i4 bluesbreaker79 Windows 1 08-08-2013 01:12 PM
Focusrite Scarlett - A Steal! RussUK General Discussion 45 05-12-2010 03:29 PM
Focusrite Scarlett justus1900 Virtual Instruments 1 12-18-2009 08:43 PM
