Pro Tools and Reaper compatibility
Hey all,
I have added to many a thread but this is my first attempt at starting one. I run Pro Tools 8 (M-Powered) on a mac pro intel quad-core. I record rock bands usually and whatever else walks in off the street. Basically, I want to record on and playback from as many channels at a time as I can in 24bit 48K. I started on protools LE with a DIGI001 back in the day and about a year ago switched to M-Powered using a Profire-2626 (thinking I could use all 26 ins and outs simultaneously) NO DICE! Pro Tools HD is prohibitively expensive and LE, M-Powered and even the resent XVX HD CRACK (shhh..) can not accommodate more then 18 in and 18 out at a time (dirty bastards, all of em'). I have however heard that with the Reaper program I will be able to record simultaneously 26in and 26out via the 2626, with additional ADAT and SPDIF hardware attached. Is anyone using both programs on there mac in OSX 5.8 with a Profire-2626 and are there any KNOWN compatibility issues with running both programs at the above mentioned bit depth and sample rate or moving audio from one to another ? ie, Tracking on Reaper - then - Editing effecting and consolidating or bouncing wet tracks down on Pro Tools - then - Importing back to Reaper to send 26 channels out of the box for analogue mixing to stereo. (Is it a pain in the ass or are they good tag team partners ?) there was a dead thread that I had a look at but it was pretty old and I would greatly appreciate someones hands on advice and help on this potentially sweet or painful setup. Cheers, Rock on! |
Re: Pro Tools and Reaper compatibility
Reaper is a great program to transfer in and out of. I don't have any of the audio interfaces you're referring to so I won't comment on that.
But I know many studios with large format consoles that use other DAWs for recording and mixing (not editing) simply because it's much cheaper. Good luck.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
HELP! Reaper > Pro Tools Issues | AlexDC | macOS | 6 | 06-20-2013 08:44 AM |
Why can't I rewire Reaper into Pro Tools. | benherron.rrr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-15-2011 03:39 PM |
PT/Reaper midi compatibility | Banana | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-06-2010 12:05 AM |
Pro Tools to Reaper... Need some help! | DeyBwah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 42 | 03-15-2010 08:24 AM |
Reaper and Pro Tools 8? | jebwick | General Discussion | 50 | 09-23-2009 07:20 PM |
