Old 08-26-2011, 05:00 PM
Sushidude Sushidude is offline
Default dont want to hear guitar amp while recording
I want to record my fender amp through pro tools but dont want to hear the amp while recording.
I have a cable going from my guitar into the input of the amp, then a cable going from the output of the amp into the input of my mbox pro. I have headphones in the output of the mbox pro, and I ONLY want to hear my guitar through the headphones, not the amp.
Is there any way to silence the amp while recording???
Old 08-27-2011, 05:38 AM
brad383music's Avatar
brad383music brad383music is offline
Default
Isolate the amp in a different room to the control room. Or is this one of those trick questions? I'm confused. Haha
Win 7, PT 9, 11 rack, superior drummer 2.2, Gibson guitars, yamaha bass, Dimebag washburn
Eleven Rack + ERXP
Pro Tools 9
Windows 7
Gibson Guitars
Washburn Guitars
Michael Kelly Guitars
Yamaha Bass
Roland TD30K
EZ Drummer 2
Superior Drummer 2.2
Old 08-27-2011, 05:55 AM
Default
Sorry, but there have been a few sarcastic questions posted lately! What I do is this:
Move my amp into a separate room and use 2 10 metre leads, but the only difference is I mic the cab, not go through the amp output. The theory is the same though. Not knowing if it's a combo amp or not, in my experience you can't mute the amp. Even if you are using just the head of an amp, DO NOT use it without connecting a speaker load. I may be wrong, but this is how I used to record before the 11 rack. Oh and instead of headphones I used my monitors, but phones will do an adequate job if they are really good quality.
Eleven Rack + ERXP
Pro Tools 9
Windows 7
Gibson Guitars
Washburn Guitars
Yamaha Bass
Roland TD30K
EZ Drummer 2
Old 08-27-2011, 07:23 AM
Bill Denton Bill Denton is offline
Default Re: dont want to hear guitar amp while recording
You didn't mention what model Fender amp you have, but...
Most of the amps (all brands) that I've seen that have a line out also have a headphone out.
Just plug something into the headphone out and it will cut out the speaker.
I usually use a 1/4" x 1/8" stereo headphone adapter (cause I've got a ton of them), but I have used other 1/4" thingies...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 08-28-2011, 11:54 AM
moff moff is offline
Like Bill said - you didn't mention what kind of Fender amp it is.
What output are you using from your amp to feed your mBox? Line out? FX send? Or (gulp) speaker out? Unless there is a dedicated "recording out" on that amp, it's probably not going to sound very good, because a lot of an amp's sound is from the speaker itself. Overdriven and distorted sounds especially will sound fizzy.
Often, plugging something into the headphone output (if there is one) will also mute your other outputs, and you may get no sound at all. That said, taking the signal from the headphone out might be OK. It will give you a "speaker emulated" signal and mute the speaker.
Here's an idea if it's a tube amp: Fender tube amps have a 1/4" speaker output on the back - most of the time two of them, "internal " (or "main" and "extension". Combos have them too. The combo's internal speaker isn't hard-wired, it's attached to the main speaker output. There are devices like the Hughes and Kettner Red Box http://www.hughes-and-kettner.com/products.php5?id=110 or the Behringer GI100 http://www.behringer.com/EN/Products/GI100.aspx which are DI boxes with built-in speaker emulation, built to be used after the power amp output. You simply unplug your tube amp's speaker (DON'T do it to a solid-state or digital modelling amp) and plug one of these in instead, rub a mic cable from the other side, and you're golden. Guitar signal (with speaker emulation) to the mBox, but no sound otherwise.
****EDIT - Sorry about this, but it appears that neither the Red Box nor the Behringer have a "dummy load" (IIRC, the Red Box used to), so DON'T use them without a speaker attached. That sort of fscks up my suggestion, unless you go to Weber and get a dummy load box. OTOH, seems kind of silly to be fretting about using an amp for recording if you have an 11R. Just saying.... - END EDIT****
Old 08-30-2011, 08:45 PM
aaron.ferrer aaron.ferrer is offline
I think you guys are overthinking this... Haha...
If the fender amp is a tube amp, with standby (hopefully it is, I don't see any point in recording an SS fender.) Just use the line out or preout into the mbox and leave it on standby.
As for the bolded part, this section is the guitar related section, not the 11R section.... Posting here does not imply that one has an eleven rack. If so, why would he have an mbox?
Old 09-01-2011, 02:15 PM
I want to thank you all so much for helping me out!! PROBLEM SOLVED!!!
It was a fender deluxe tube amp and basically when I put an additional cable in the slot on my fender that said power amp in, the sound would go away.
THANKS AGAIN!!!!!!
Old 09-02-2011, 01:35 PM
That method might work if he is recording clean guitar and doesn't want any "grit". As soon as you try to do any distortion or overdrive, while taking the output from the any preamp output (line out/FX send), it WILL sound fizzy and bad, because much of an overdriven/distorted sound depends on the frequency response and "filtering" of the speaker itself, hence speaker simulators like the Red Box and GI100.
Yeah, my bad. Posts in this section are fairly heavily weighted toward the 11R, and I just followed that trend...
Old 09-02-2011, 09:42 PM
There are plenty of IR plugins out there. IR-a-Live is a free IR loader, and there are free IR's out there that would give more flexibility than the red box or the GT1000. Even running into Eleven Free would work. Don't believe the redbox or GI100 allow you to kill the volume back to the amp though. I guess OP's solution of plugging into the power amp jack cuts off the connevtion to the poweramp.
Old 09-04-2011, 01:41 PM
I hadn't thought of IRs. When I originally suggested the RB and GI100, I was thinking they could use it instead of the speaker, but was unaware that neither have a dummy load. OTOH, I was sure the old RB I had 15 - 20 years ago did, though.
Can't hear track I'm recording on but can hear all others Durstlaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-14-2022 01:24 PM
Pro Tools shows signal but I dont hear anything??? drumzalicious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-22-2010 11:30 AM
Recording is Enabled but when I push play, I can't hear the live guitar notr2d2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-21-2010 11:44 AM
8.0 cs3--Dont hear take while recording... scottleader Pro Tools TDM Systems (Mac) 10 10-14-2009 03:28 PM
Help...Why dont I hear anything out my speakers cristol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-22-2007 10:34 PM
