Old 10-01-2013, 08:04 PM
smallfri145 smallfri145 is offline
Default No sound during playback
I'm new to Pro Tools 11, and Pro Tools in general. I loaded a basic "blues" template, and hit play to hear the MIDI drum track, but no sound comes out. I just have my headphones plugged in to the headphone jack. I have ASIO4ALL v.2 as my playback engine, am I missing an essential component? Is ASIO4ALL the audio interface?
I use Windows 7 (I would give the Sandra report, but it always crashes), Six-Core Processor 3.5 Ghz, ASIO4ALL v.2, 8GB RAM.
Old 10-01-2013, 10:07 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: No sound during playback
Have you created an Instrument track and inserted a drum plugin on it, and also selected the correct I/O on that track?
Have you assigned the output of the Midi track to the drum plugin or is the Midi actually on the Instrument track?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 10-02-2013, 04:01 AM
If you're having crashes with getting a Sandra report you have bigger problems than figuring out how PT works. As far as working with PT I'd suggest getting a good book or two. Most of the stuff that's out there for PT10 will suffice for getting you started with PT11. PT is NOT plug and play software and has a rather steep learning curve. It's not Guitar Hero or Garageband.
Also mandatory is optimizing your computer for PT. Searching here on the DUC or Google is your friend for that and other things.
Jack
QAPLA!
Old 10-02-2013, 04:14 PM
Got it to sound, thanks a lot!. It was just that some of the plug-ins hadn't been loaded. Thanks for your help!
Monitor sound vs playback sound sean_pc Pro Tools 10 4 06-22-2013 06:57 AM
Playback doesn't sound the same! gz131 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-09-2013 08:37 AM
No Sound or Playback with PT 10. Danny Winn Pro Tools 10 7 07-26-2012 11:55 AM
no sound/playback chewyone Pro Tools SE and Essential (Win) 1 03-22-2011 10:01 AM
No Playback Sound max88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-05-2004 01:36 AM
