Old 07-09-2018, 03:08 PM
wyman wyman is offline
Default VCA Masters and Latency
Hi Folks,
I've been having trouble with VCA masters and sessions with high (>4000 samples) latency. When I'm writing automation using a VCA fader, as I'm moving the fader / hitting the mutes, the channels assigned to that VCA group behave in sync. When playing back, though, the individual channels move noticeably slower. I hesitate to call this an ADC thing, because even if I turn off ADC, the behavior is consistent.
I reproduced the behavior in a new session by creating two new audio tracks, assigning them to a VCA group, then putting some heavy-latency plugins making for a few thousand samples of delay on one of the tracks. Same thing: the individual tracks move noticeably later than the VCA does.
I'm using A C24. I see the discrepancy both in the mix window and on the C24, though it seems a little more obvious on the C24.
Maybe this is exactly how VCA's are supposed to work and I'm just a dummy, but it's making for some clumsy automation passes.
Anyone have any insight?
Thanks!
HD Native
Mac Pro Trashcan 3.5 GHz 6-Core Intel Xeon E5
Pro Tools 12.8.3
OSX 10.12.4
Old 07-09-2018, 10:29 PM
its2loud its2loud is online now
Default Re: VCA Masters and Latency
You need to be running PT 12.8.2 or later. The initial 12.8 version broke the VCA function. This may, or may not be your issue.
Old 07-10-2018, 07:42 AM
Sorry, I'm on 12.8.3. Will edit OP for clarity. Thank you for the insight.
Old 07-10-2018, 12:38 PM
Talked to Avid CS this AM, they told me to upgrade to 2018.4 to see if the problem persisted. It did, and in troubleshooting, I found some odd behavior.
2 aux tracks assigned to a VCA Master, 4 instances of Maxim on one track to incur some latency.
With delay compensation off, assigned aux tracks move in sync with VCA fader
Turn on delay compensation, the assigned tracks are noticeably behind.
Turn off delay compensation again, the assigned tracks continue to be behind.
Here's where it gets real weird:
Remove all the plugins, assigned tracks are still behind VCA master.
I made a little video to send them, and I'll share it here, too, in case anyone has any insight:
https://www.dropbox.com/s/ohp7k7jxjk..._5188.MOV?dl=0
Old 08-07-2018, 11:30 PM
Sounds Sounds is offline
I want to scream with you!!!!
I don't have a great desk like you but ADC is causing me to lose my hair!!! the minute I turn on ADC everything is behind! if I turn off ADC everything is ok! but with the regular (no adc)!!!
I think its a bug! FR!!!
Old 08-08-2018, 04:31 AM
This has now been logged as a bug: ARST-1304. We’ll see how long it takes to fix.
Old 08-08-2018, 07:36 AM
TOM@METRO's Avatar
Thanks for pushing this. I'ts very helpful.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Using VCA Masters while recording SplitTheDifferenceAudio Pro Tools 2018 0 06-28-2018 07:19 AM
Masters Chickenhawked General Discussion 23 05-20-2013 02:33 PM
Masters bypassed ? JoeGuitar VENUE Live Sound Systems 2 02-28-2013 01:00 PM
192 Masters zoggied Tips & Tricks 4 04-10-2003 02:17 PM
EQ masters, how!? smcoptyltd Tips & Tricks 1 11-06-2000 05:35 AM
