Old 11-05-2018, 07:29 PM
Acousticwarrior Acousticwarrior is offline
Default Virtual SC levels on Pro Tools
Guys, need some guidance/assistance for an issue I have not encountered before.
Set up: 4 x S16 stageboxes, 2 x S3L-X systems ( 4.6.1.4), 2 x Macbook with Pro-Tools ( Yosemite Pro Tools 12.4 at FOH, El Capitain PT 11.3.1) 2 x production toolkit
Issue: Both systems record fine, all 64 tracks. Mon rig plays back at exact same gain level, when switched over to mic input mode. System at FOH for some reason records at about 15 db lower level overall on all channels. All settings at SL3-x seem to be like we have used them on many shows with other engines before ( this rig is a touring rental), so this might be an issue? Is there an overall level adjustment of AVB stream I do not know if? Any hints/ ideas, as this renders virtual SC completely useless for me. Any comments would be appreciated.
Old 11-06-2018, 07:45 AM
emluper emluper is offline
Default Re: Virtual SC levels on Pro Tools
Sounds to me like the metering on the FOH console is set to Peak and the Mon console is set to RMS. I would double check that.
Old 11-06-2018, 09:42 AM
RyanJ's Avatar
RyanJ RyanJ is offline
The recording on an IO shared system is straight off the head amps, a proper redundant recording. This means the gains that are recorded are the gains set by the master of the stage boxes. So if your MON engineer is master, and your MON gains are set 15dB down from FOH gains, then your playback will be 15dB down at FOH, the simplest way to get around this is to set your fader levels in PT to match the difference in gain between MON and FOH...
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Old 11-06-2018, 10:41 AM
Ryan, understand, is there a way to circumvent by recording the direct outs instead for virtual SC? As there is an output gain available. And how would This need to be set up. All meters RMS at any piece of equipment by the way.
Old 11-07-2018, 08:35 AM
You can use the Direct Outs page in the Patchbay to assign the DO's to Pro Tools. If you're using it primarily for VSC make sure you have the individual direct outs set for Top of Channel (set in the Patchbay), otherwise you'll be recording all of your eq, compression, expansion, and any plug-ins to Pro Tools. Also, the max gain on the direct output is 12dB.
suggested levels for all MIDI volumes in a Virtual Instrument. aeide Virtual Instruments 7 08-10-2017 04:33 AM
Help! Pro Tools FCP CD Levels moblues Post - Surround - Video 8 01-05-2009 10:18 PM
levels within pro tools? weezerboy Pro Tools TDM Systems (Mac) 9 04-22-2006 04:07 PM
Levels in Pro Tools WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-17-2005 05:03 PM
LEVELS IN PRO-TOOLS 5.1 MR. BLISS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-01-2004 03:30 PM
