Mute on audio track switches off when I play the track
I have ProTools HD on a G4 867.
I have one track in a session which will not stay muted. If I mute it, then hit play, the mute immediately switches off and I hear the track. The same thing happen if I start at the beginning of the region, or at any other location in the region. I have automation data on this track, but I have this on many other tracks which don't exhibit this behavior. I have never had this happen before. What is going on? [img]images/icons/confused.gif[/img] Thanks, Mike |
Re: Mute on audio track switches off when I play the track
best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Rich,
I have not written any mute automation data for any of the tracks in this session. I have only written volume automation data. When I look at the mute display for this track, I see a single point at the beginning at the top of the scale, and a solid horizontal line for the remainder of the track. So, I don't think the problem lies in mute automation data (unless I am missing something). Any other suggestions? Thanks! Mike |
Automation would be the only thing that would cause that behavior. Try the suggestion above: go to the track in question's mute automation playlist and triple click to select the entire length of that track, then hit delete.
It is possible to accidentally write automation data on a playlist other than the one you're working on. For instance, if you're in absolute write mode, all enabled parameters will be written, whether you touch them or not. That's one of the only reasons the automation enables window even exists. If the suggestion made in the earlier post doesn't fix your problem, then I congratulate you for having a problem that I've never ever ever seen or heard of. Good luck. |
A way to mute a track while un-muting another track w one click? | DrummerGuy09 | Tips & Tricks | 7 | 06-12-2022 07:57 PM |
Pro Tools 9 won't play audio after create new track. | shaun_curran | macOS | 0 | 01-26-2011 05:26 PM |
Can't Mute or Change Volume on Audio Track and Instrument track | FunkTools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-10-2010 04:40 AM |
When I enable a track to record and then hit 'play' the track will remain silent | Rainerbird | Pro Tools M-Powered (Win) | 2 | 08-07-2009 09:41 PM |
can't hear audio with track in play mode | slim chrispy | Tips & Tricks | 2 | 06-08-2004 07:06 AM |
