Old 05-15-2010, 05:35 AM
GW GW is offline
Default Re: Free Mixing & Mastering Templates
Like Viktor Borge used to say - It's your lingo, I'm only using it! (...don't even drink the stuff myself, so I don't have to know how to spell it.) Hope it didn't make the suggestion less valid?
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Old 05-15-2010, 06:44 AM
waltz mastering's Avatar
waltz mastering waltz mastering is offline
Originally Posted by jadown View Post
Are there any free mixing & mastering templates that I can download that have different genres other than the ones that comes with Pro Tools?
IME, the best templates or presets to start from are the ones that are titled "Flat"
Tom W
www.waltzmastering.com
Old 05-16-2010, 01:07 AM
tamasdragon tamasdragon is offline
Priceless!!!
and......
TRUE!
my blog:Tamas Dragon
Old 02-19-2011, 02:34 PM
lberrios1962 lberrios1962 is offline
Originally Posted by elmostephane View Post
Here's a bit of a guideline to get you on the track of clean sessions...:
As a general rule, every track should be routed to a bus that will group different frequency areas:
kicks
drumloops (as well as parallel comp drumloop bus)
guitars (divided into more buses if using acoustic + electric, both then router to a master guitars bus)
piano
synths
bass
reverb1
reverb2
delay (really short that acts like reverb)
delay (FX, usually triplets with low feedback)
delay (FX, quarter note with longer feedback)
master fader
Every bus should have:
HPF on it, where you put that filter depends on the instrument being processed.
EQ should be applied with "niche EQ" techniques.
transient designer (only on some buses though)
Compressor
brightening EQ
Tape saturation
Master should have:
EQ
Comp
Harmonic enhancer
Brightening EQ
tape saturation
Limiter
But then again, this is only a guideline and may not work in every situation. But at least it'll give you a good starting point...
Good Luck!
Are you a mastering, mixing engineer, musician..or just a music student?
If you have to apply all that during a mastering session somebody would be in real problems. Is not need to use so many processing during mastering, it's ridiculous. Not even everything that you mentioned during mixing either. Way too much processing.
Old 02-19-2011, 06:42 PM
se.audio's Avatar
se.audio se.audio is offline
Mixing and mastering engineer.
As these were just quidelines for someone who wasn't too sure where to start, I put everything usually needed on there, but obviously, each project needs different things. The processing on the master would not normally be applied in mixing but in mastering (along with other processing on the MS channels...)
As far as what I mention on the mixing channels, these are required for mediocre recordings (which I assumer the original person asking the question would have since if he/she had good recordings, they'd probably know what to do anyway...)
se.audio
  #16
Old 02-19-2011, 07:35 PM
browniespeaks browniespeaks is offline
Oh botha!
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Does Pro Tools have on board Mastering preset templates? Danny Winn Pro Tools 10 3 09-10-2012 08:34 AM
Mixing and Mastering spidey901 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-12-2007 10:40 AM
mixing templates P.O. Digidesign Hardware & Software 1 02-28-2007 09:12 AM
mixing templates P.O. Digidesign Hardware & Software 0 02-02-2007 10:49 AM
Mixing / Mastering for TV???? pepperman Tips & Tricks 5 07-23-2003 05:24 PM
