Authorization code will not work
I just purchased the Pro Tools LE 6.9/6.9.2 upgrade for my system and my authorization code will not work. I installed version 6.9.2 on Mac OS Tiger and everything works fine, the app launches. It still asks me for a code, but if I click cancel it will still run. The only thing that does not work without the code are the plug-ins. I used the authorization code inside the 6.9 booklet (starts with DIGI) and it says it is incorrect. I'm thinking that it's recognizing the code from 6.9 and NOT from 6.9.2. Can anyone help?
Re: Authorization code will not work
The code is for the Pro Tools application -not for the plug ins. You need to read the literature that cam with the plug ins, which will explain the authorisation process, which will be via ilok, or challenge/response.
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
PT LE 7.4 Authorization code doesn't work | 51sth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-05-2012 08:33 AM |
Authorization code wont work! | deeceechillen | General Discussion | 5 | 05-11-2010 07:59 AM |
Upgraded to 7.4.2 and now my authorization code doesn't work | ryanm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-23-2008 10:13 AM |
Upgraded to 7.4.2 and now my authorization code doesn't work | ryanm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-22-2008 09:18 PM |
Authorization code won't work | johnjm22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-21-2007 09:11 AM |
